Tue, Nov 19, 9:33 AM CST
Subject: Hip Lock in P-8
RodS ( ) posted Fri, 02 October 2009 at 8:19 AM · edited Tue, 19 November 2024 at 7:38 AM
I'm having an issue with hips 'locking' in Poser 8. I'm a beginner with Poser, so it's highly possible I've missed something somewhere, but haven't stumbled onto it as yet.
If I load Victoria, everything is fine with the figure zeroed. I can apply rotation to the hips with no problem. However, if I apply one of her pre-loaded poses, then want to tweak the hips a bit, I'll find the hips are 'locked' - in other words if I select her hip and try to rotate, the entire body rotates. It's the same if /i try to bend her forward or back - the entire body just rotates. I can apply a different pose, and she will go into the pose with no problem, but again, I cannot adjust the hip.
Am I missing something??
Thanks,
Rod
"I reject your reality and substitute my own" - Adam Savage
LaurieA ( ) posted Fri, 02 October 2009 at 8:27 AM
I'm thinking if you want to adjust the hip and have the figure not completely rotate, you should turn IK on so that the feet stay put where they are.
TrekkieGrrrl ( ) posted Fri, 02 October 2009 at 8:34 AM
 What Laurie said is correct. If Inverse Kinematics are off, translating/rotating the hip is the same as doing it to the BODY. Everything goes :)
So if you want to tilt her hip, turn IK on. OR tilt her, and tilt legs and abdomen the opposite way. Whatever you prefer :)
The Hip is the main body part of Poser. It's the one that controls the orientation in Poser space and everything :)
Vestmann ( ) posted Fri, 02 October 2009 at 8:34 AM
Yes, you'll want to turn on IK.  Go to Figure - Use Inverse Kinematics and check left and right foot. You could also check her hands if you want them locked.
 Vestmann's Gallery
hborre ( ) posted Fri, 02 October 2009 at 9:15 AM
Yep, that's my vote.
RodS ( ) posted Fri, 02 October 2009 at 10:26 AM
OK - I figured it was something simple I'd missed.... I'll look at IK when I get home tonight (I'm 'supposed' to be working right now ;-O). Thanks, everyone!
The Hip is the main body part of Poser. It's the one that controls the orientation in Poser space and everything :) <
So the hips control the universe, eh? I could go somewhere really bad with that, but this is a family show...... ;-)
Rod
