Sun, Feb 9, 7:38 PM CST
Subject: Moving around content
redtiger7 ( ) posted Wed, 07 October 2009 at 6:09 PM · edited Sun, 09 February 2025 at 7:24 PM
IS it possible to move the content models around to different folders without screwing anything up?
markschum ( ) posted Wed, 07 October 2009 at 6:25 PM
You can normally move the content of libraries/character/prop etc without much trouble. Do NOT move geometries or textures around and dont move the !Daz folder . Some props have the obj in the props folder, those you cant move without editing the prop file.
JenX ( ) posted Wed, 07 October 2009 at 6:26 PM
What do you mean by "moving content around"?  Are you trying to put things in a different runtime, or do you want your geometries in another spot?  The former, you should be fine, so long as you link the runtime in your library.  The latter could cause you a lot of problems, including having to manually locate figures every time you try to load them from the library.
basicwiz ( ) posted Wed, 07 October 2009 at 6:29 PM · edited Wed, 07 October 2009 at 6:30 PM
Using something like 3Pdo, you have a good chance of making it work as long as you only move things within major folders... like from one folder to another in the Characters folder. If you move geometries or textures, it's broken for sure.
I think a better solution is PzDB, which takes a database approach and allows you to create your own groups without actually moving anything. The downside of this is, if you want it to load things automatically, you have to use pRPC (which is installed with it) but THAT doesn't play will with some of Poser's functions, so I wind up turning it off and on a lot.
It's all in what you prefer. Look at both programs. I have a feeling one or the other will solve at least your major issues.
JimTS ( ) posted Wed, 07 October 2009 at 6:31 PM · edited Wed, 07 October 2009 at 6:33 PM
Almost Anything can be moved some way open a cr2 as a text doc in editpad or whatever and search for obj or image reference if those lines are edited to reflect the directory changes of the geometries and textures the altered Poser object should Open
This applies to mc6 cm2 pp2 hr2 probably mt5's there's Poser files and then there's resource files meshes and image maps
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
 Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
redtiger7 ( ) posted Wed, 07 October 2009 at 6:33 PM
I understand about the geometries and textures. But I was wondering if there was anything pointing towards the actual .cr2/.pp2 file. Can I just drag that to some other folder. I'm trying to rearange my library in a more cohesive order.
JimTS ( ) posted Wed, 07 October 2009 at 6:36 PM
Within each of the Library substructures yes
Also mostly you can rename pz2 to cm2 and some of those crossover
Charles Péguy
JenX ( ) posted Wed, 07 October 2009 at 6:40 PM
 Oh, so you're trying to re-organize your runtime?  Those should be fine.  I don't see why moving them should be an issue at all.  I do it all the time :)
redtiger7 ( ) posted Wed, 07 October 2009 at 6:42 PM
Okay, so I want to create, say, a Victoria 4 folder, with sub-folders for clothes, hair, mods, etc... and sub-sub folders for each clothing set, hair style, etc...Now can I just create a Libraries/V4/hair folder, or does it HAVE to be in Libraries/Hair?
JimTS ( ) posted Wed, 07 October 2009 at 7:58 PM
That isn't possible in Poser you could have a V4 Runtime with sets of v4 based cr2"s in the character library  a set up for Hair etc.
Charles Péguy
modus0 ( ) posted Thu, 08 October 2009 at 1:40 AM
It has to be Libraries/Hair, otherwise Poser won't see it.
What you can do, is make a new folder titled "V4" and have the Runtime (Runtime/Libraries/Hair etc.) setup in that folder, and add it to Poser.
________________________________________________________________
If you're joking that's just cruel, but if you're being sarcastic, that's even worse.
