Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 12:41 am)
Netherworks has a Hair Conversion System for V4 which might work. It can be found here:
http://www.daz3d.com/i/3d-models/-/hair-conversion-system?item=7903&_m=d
Maybe you own Princess Diaries which was a pose set for V4 from Daz3d - guess it's no longer available .The package included a V4 fit for Sapphire Fox Hair & Babydoll Hair. You can PM Firebirdz to see if it's available anywhere currently .
Alice's and
GND4's Tailor !
Check my free clothing
fits : www.alizea3d.com
I don't have Princess Diaries, unfortunately, and you're right that it appears not to be available any longer. I will PM Firebirdz.
As for using the xyz dials to place the hair, I use that method whenever possible, but it doesn't work so well with conforming figure hair. You can adjust it and use the Set Figure Parent instead of Conform To, but I doesn't behave correctly when you move V4s head and the Bend, Side-To-Side don't work so well either.
Does anyone know where or if there is a V4 refit of Quarker's Sapphire Fox Hair? It was one of my favorites with V3 that I'd long forgotten about until digging through the old runtime folders. I searched whatever3d and the Freestuff. I also tried to run it through Crossdresser but it didn't work out so well.
