Thu, Dec 19, 10:46 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 19 10:29 pm)
Subject: Joint centre question.
xantor ( ) posted Tue, 13 October 2009 at 11:03 AM · edited Thu, 19 December 2024 at 10:36 PM
If I am making an object and it is non symmetrical, how can I find a pivot point in it to put the joint centre at?
For example, the picture shows a tube and a thin box, the centre of the box is not the rotation point, how do I find a specific point in the box to put the pivot point?
This happens a lot with mechanical objects I make where it is difficult to find the exact rotation centre so it would be great if anyone has a solution.
PhilC ( ) posted Tue, 13 October 2009 at 11:16 AM
I usually set the preview style to wire frame then use one of the orthographic cameras and the joint parameter editor to position the center where I require.
xantor ( ) posted Tue, 13 October 2009 at 11:19 AM
Quote - I usually set the preview style to wire frame then use one of the orthographic cameras and the joint parameter editor to position the center where I require.
That is what I usually do as well, but I was hoping that there would be a better way.
markschum ( ) posted Tue, 13 October 2009 at 11:25 AM
Yup, thats the only way I know to do it.
It is possible to write a script to scan the geometry , get the bounding box , and find its center but just visually is usually good enough.
xantor ( ) posted Tue, 13 October 2009 at 12:03 PM
Quote - Yup, thats the only way I know to do it.
I already have a python script that finds the centre of objects, but asymmetrical objects and ones that don`t have the pivot point in the centre are difficult to get right.
