Sat, Jan 25, 4:50 PM CST
Subject: Help with V8
Monsoon ( ) posted Fri, 06 November 2009 at 8:10 AM · edited Mon, 20 January 2025 at 4:13 PM
Help anyone.
My V8 is so sluggish it's barely usable. It's just like back in V4 and V5 when I couldn't use OpenGL yet I can't seem to find the old 'optimized, wire frame' mode.
It seems like every move I make has to buffer first. Anyone else experiencing this?
Windows XP SP2
3 gb ram
Nvidia 8600 GT   512 mb
wabe ( ) posted Fri, 06 November 2009 at 8:19 AM
Hi Mark,
what exactly are you facing? Could it be that by any reason you see the anti-pirate mode that makes Vue crash like crazy? I heard there were some serial number issues that people had. This could cause what you see. Check your account maybe at e-on and see what is registered there.
Monsoon ( ) posted Fri, 06 November 2009 at 8:37 AM
Heya Walther,
I checked my account and everything seems in order. I didn't have any trouble installing or anything.
When I'm working for instance, and I go to turn a model, nothing happens then, of a sudden, it'll pop over, then the same again. In the editors I click ok and it takes a while to disappear and then my cursor will disappear and it all bogs down and I can't manipulate anything.
Boggle....
M
wabe ( ) posted Fri, 06 November 2009 at 8:44 AM
Could you maybe post your display preference settings? Smells a bit as if there is a problem there. "Background draw" is one of the candidates. Try to change that to see whether it makes a difference.
Monsoon ( ) posted Fri, 06 November 2009 at 9:06 AM
I will when I get home this evening. I agree. It feels just like those old Open GL problems one of which was background draw. Thanks for the reply!
bruno021 ( ) posted Fri, 06 November 2009 at 9:09 AM
The faulse  pirated serial issue will make Vue crash. If you don't crash, then it is something else.
FalseBogus ( ) posted Fri, 06 November 2009 at 9:16 AM · edited Fri, 06 November 2009 at 9:23 AM
I had sluggish response with smooth shaded previews with my GF8800GT.
Settings views to flat shaded helped a lot with large detailed scenes.
You can try dropping the setting for opengl from settings down from shader 4 too.
[edit]
just tested some more.
I get rid of the sluggishness by dropping the opengl settings in options.
From opengl 2.1 (shader 4) -> opengl (fixed hardware pipeline)
[/edit]
dburdick ( ) posted Fri, 06 November 2009 at 10:07 AM
Mark,
Try updating your Open GL drivers for your card.  I had exactly the same problem you did and after updating my Nvidia driver, the problem went away.
Monsoon ( ) posted Fri, 06 November 2009 at 11:03 AM
Thanks guys....I'm gonna do all of the above!   I'm very anxious to play!
Rutra ( ) posted Fri, 06 November 2009 at 11:05 AM
Or you may try not to use the new shader 4 mode but use instead the old standard hardware opengl.
Monsoon ( ) posted Sun, 08 November 2009 at 7:24 AM
The drivers were key...now we're slick as can be!
bruno021 ( ) posted Sun, 08 November 2009 at 8:55 AM
Cool!
