Vue F.A.Q (Last Updated: 2025 Feb 23 3:59 pm)
Hi Mark,
what exactly are you facing? Could it be that by any reason you see the anti-pirate mode that makes Vue crash like crazy? I heard there were some serial number issues that people had. This could cause what you see. Check your account maybe at e-on and see what is registered there.
Heya Walther,
I checked my account and everything seems in order. I didn't have any trouble installing or anything.
When I'm working for instance, and I go to turn a model, nothing happens then, of a sudden, it'll pop over, then the same again. In the editors I click ok and it takes a while to disappear and then my cursor will disappear and it all bogs down and I can't manipulate anything.
Boggle....
M
I had sluggish response with smooth shaded previews with my GF8800GT.
Settings views to flat shaded helped a lot with large detailed scenes.
You can try dropping the setting for opengl from settings down from shader 4 too.
[edit]
just tested some more.
I get rid of the sluggishness by dropping the opengl settings in options.
From opengl 2.1 (shader 4) -> opengl (fixed hardware pipeline)
[/edit]
Help anyone.
My V8 is so sluggish it's barely usable. It's just like back in V4 and V5 when I couldn't use OpenGL yet I can't seem to find the old 'optimized, wire frame' mode.
It seems like every move I make has to buffer first. Anyone else experiencing this?
Windows XP SP2
3 gb ram
Nvidia 8600 GT 512 mb
