I could believe that you didn't get much if you used the volumetric world with quality set over to the high side. The image looks like it would have been awesome, if you ever have the patience tolet it run. You mighht try checking the quality setting on volumetric worlds, try running it with something less than 50. You might lose some of those rays that your fist image only hints at. Ya gotta love what Bryce can do. Someday the hardware will catch up with it and we'll be able to use some of these jewels.
Also, for you to possess the WHOLE picture like that, I know you were rendering normaly...you need to choose the rendering option to "Render To Disk", this will bypass your video card having to display the changing results of the ongoing render. Which it will still do, even if your monitor is turned off. But, THE thing that will have the MOST effect will be using a lesser seting in volumetric world options as mentioned above. Or, as you have found, turn it off altogether. Agent Smith
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
when I wanted to be what I am now"
Thanks for the advice. I changed the atmosphere and rendered the result. Took about 8 hours compared to 6 days and NO, when I returned, it had not locked up because I let it continue rendering that sixth day and finally said enough!. Let me know what you all think of the finished image in the gallery.
http://schuetzenpowder.com/sigs.jpg
