Thu, Jan 30, 11:09 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 10:50 pm)
Subject: Help! I've lost a floating window!
ChrisV ( ) posted Wed, 23 December 2009 at 4:47 PM · edited Thu, 30 January 2025 at 11:09 AM
Since using P8, I've found it more convenient to have the library in a floating, non-dockable window which I can move out of the way when accessing the parameters/properties section.
Today, I moved the window too far and I can't access it or recover it to show on-screen.  I've tried doing a factory default restore but the window is still missing.  (Yes, I've ticked the libraries window to 'on' in the drop-down menu.  Unfortunately, I can't even force showing the window by using a higher resolution on my monitor as it's an LCD operating at its max resolution.)
Anybody know how to restore this window to show on screen - perhaps with a python script?
markschum ( ) posted Wed, 23 December 2009 at 5:11 PM
with Poser 7 and earlier you can delete the UI prefs.xml file thats was in documents and settings/user/application data /poser 7    or in the program library folder.
LaurieA ( ) posted Wed, 23 December 2009 at 5:26 PM
Your best bet is to go to Preferences and "Launch to Factory State". Sometimes that's the only way to get them back where you can grab them ;). Of course, you'll need to set your interface up like you want it again, but...
ChrisV ( ) posted Wed, 23 December 2009 at 5:36 PM
Quote - Your best bet is to go to Preferences and "Launch to Factory State". Sometimes that's the only way to get them back where you can grab them ;). Of course, you'll need to set your interface up like you want it again, but...
Hi Laurie,
As per my first post, tha's exactly what I DID do (and first) but I still can't access the window - it still 'appears' to be off screen.
How do I delete my preferences file to remove the errant screen location for this window?
Thanks for your help
LaurieA ( ) posted Wed, 23 December 2009 at 5:54 PM
If you're running an OS Vista or above, go to CUsers"Your Computer Name"AppDataRoaming.
Theres a file there called "Library Prefs.xml". Delete that and restart Poser. I'm using Poser 7, and I'm just assuming Poser 8 puts them in the same place...
LaurieA ( ) posted Wed, 23 December 2009 at 5:56 PM · edited Wed, 23 December 2009 at 5:57 PM
Quote - Hi Laurie,
Oh, I apologize for missing that. My only excuse is that I'm not feeling too well this evening ;o).
ChrisV ( ) posted Wed, 23 December 2009 at 6:22 PM
Quote - If you're running an OS Vista or above, go to CUsers"Your Computer Name"AppDataRoaming.
Hi Laurie,
I'm running on XP under SR2.  Checked all the .xml files in P8 and under windows; no such file exists.  Opened the poser ini file and changed the line: library pallete location - still no use!
Any other suggestions or is it best to contact Smith Micro?
markschum ( ) posted Wed, 23 December 2009 at 6:27 PM
You want ui Prefs not library prefs in
c:documents and settings/owner/application data/poser 7
instead of owner it may be your username
ChrisV ( ) posted Wed, 23 December 2009 at 7:03 PM
Quote - You want ui Prefs not library prefs in
Nope, no good.  Looked under Smith MicroPoser8 - nothing listed
Even tried setting the UI Previous to zero within Poser8.ini file - still no good
I guess I'll have to contact Smith Micro direct unless anyone else has any ideas.
LaurieA ( ) posted Wed, 23 December 2009 at 7:17 PM
Aw, dang. Hope someone comes along who can help ya ;o).
And yes, I gave you the wrong file...lol. Just call me the stupid blonde. Geese I'm all outta sorts tonight. I'm gonna quit while I'm not ahead...lol.
ChrisV ( ) posted Wed, 23 December 2009 at 7:22 PM
Hi Laurie
Thanks for your help anyway.  I've referred it to SM for them to sort out
Hope you feel better tomorrow!
Chris
Plutom ( ) posted Wed, 23 December 2009 at 9:21 PM
The .xml files are there, they are just hidden and I don't know where to go to unhide the files--I did in XP and win95.  Anyone know where to go to unhide those critters?  Jan
jonnybode ( ) posted Thu, 24 December 2009 at 1:04 AM
Hi!
Im on swedish XP and for me its, Vertyg / Mappalternativ / Visning / Visa dolda filer och mappar.
Guess that on an english system its: Tools / Folder options / Show / Show hidden files and folders.
Dizzi ( ) posted Thu, 24 December 2009 at 8:08 AM
Guys... just type "%appdata%Poser8.0" without quotes in the explorer Address bar... it's that simple...
The ui prefs are in the subfolder "English". And the prefs are not hidden at all.
ChrisV ( ) posted Thu, 24 December 2009 at 12:14 PM
Hi All
Problem Solved!
Although I had a reply from Smith Micro, I still had some difficulty in locating the required files
Many thanks to Dizzi for the suggestion - they showed up straight away and I deleted the neccessary files and restarted P8 successfully
Thanks to all
Apple_UK ( ) posted Thu, 24 December 2009 at 3:14 PM
 window > libraries
