Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 10:50 pm)
Quote - Your best bet is to go to Preferences and "Launch to Factory State". Sometimes that's the only way to get them back where you can grab them ;). Of course, you'll need to set your interface up like you want it again, but...
Hi Laurie,
As per my first post, tha's exactly what I DID do (and first) but I still can't access the window - it still 'appears' to be off screen.
How do I delete my preferences file to remove the errant screen location for this window?
Thanks for your help
Quote - If you're running an OS Vista or above, go to CUsers"Your Computer Name"AppDataRoaming.
Theres a file there called "Library Prefs.xml". Delete that and restart Poser. I'm using Poser 7, and I'm just assuming Poser 8 puts them in the same place...Laurie
Hi Laurie,
I'm running on XP under SR2. Checked all the .xml files in P8 and under windows; no such file exists. Opened the poser ini file and changed the line: library pallete location - still no use!
Any other suggestions or is it best to contact Smith Micro?
Quote - You want ui Prefs not library prefs in
c:documents and settings/owner/application data/poser 7
instead of owner it may be your username
Nope, no good. Looked under Smith MicroPoser8 - nothing listed
Even tried setting the UI Previous to zero within Poser8.ini file - still no good
I guess I'll have to contact Smith Micro direct unless anyone else has any ideas.
Since using P8, I've found it more convenient to have the library in a floating, non-dockable window which I can move out of the way when accessing the parameters/properties section.
Today, I moved the window too far and I can't access it or recover it to show on-screen. I've tried doing a factory default restore but the window is still missing. (Yes, I've ticked the libraries window to 'on' in the drop-down menu. Unfortunately, I can't even force showing the window by using a higher resolution on my monitor as it's an LCD operating at its max resolution.)
Anybody know how to restore this window to show on screen - perhaps with a python script?
