DAZ|Studio F.A.Q (Last Updated: 2024 Dec 26 8:06 pm)
You dont really need advise only not to be so modest LOL. Great work and I read you know plenty and spend lots of time on renders. Be proud you did great
You can also reach me on skype.com to talk name
ladiesmen22
People dont care what you know, until they
know you care
Use Quad core with 8G memory & ATI 5770
Poser Pro 7 & Poser 8 Sr3
Daz 3.2 adv 64 bit
Ive actually learned something from this thread ....32 lights with 200% ambience looks great. I think ill try it ..thanks DS3 master on your first image.
Geeze , can you believe this guy....post an image like that and then asks for help!! Ive spent hundreds of hours trying to find the right tools and settings to get images like that!
wespose
Above is a screen grab of the LD2 Pro settings I used. They are a bit different from what I thought they were. I forgot that I had dropped the light count and increased the ambient value to speed up render times. I also set the shadow softness for the Sunlight to 4.5% (under Light Dome 2 Pro in the scene properties tab). The spot light was set to 24% inensity pointed at G4s head. Without "trees" blocking some of the lights like in this image, you might need to turn the sky/sun lights down a bit more.
Hope this helps!
DR
__________________________________________________________
My Rendo Gallery ........ My DAZ3D Gallery ........... My DA Gallery ......
The result is superb! The difuse shadows are astonishing, along with the specular highlights and the textures. A copy of that render is going into my inspiration art file!
You should honestly think about putting together some tutorials on how to accomplish such results, I for one would be an avid reader of such information!
McKay001,
Thanks for the compliment! I don't know that I could do a true tutorial, since I'm just learning DS myself, and my workflow is basically set up the scene, set the lights, test render, tweak, test render, tweak, test render, tweak mats, test render, tweak mats, test render, tweak lights, test render, etc.
I'm more than willing to share any settings, and any explanations I might have for using the settings (if there is some reason other than I thought it might work). I would also be willing to put together some basic elements that say everyone with DS3A might have, and do a bit of a tuorial on it. My only requirement would be that no one get upset over slow developement of the tuorial - I have to start teaching an evening class at the local community college next week, so my creative time will be limited.
If you're interested, I recently posted a new image in my gallery using the basic UberEnvironment light set in DS3A. It's by no means a great image, but it does show that good results are pretty easy to achieve even for a DS newb.
DR
This is my first scene/image with DS3A. I almost always use Carrara, but with DS3A being 64bit, I've started to seiously play with it. I used LightDome 2 Pro (32 lights, 200% ambient) and one spot for lighting. I thought I'd let the experts here look at it and give me some tips. I had to modify the default settings in LD2 Pro quite a bit to get softer lights/shadows. I also changed the default shadow setting on the sun light to soften the sun shadows. I think that using DOF might have helped to highlight G4 more.
It seems like materials settings need to be modified in most cases, just like in Carrara. I'm going for a realistic toon look, not true realism with this image. Any tips on materials settings would be very welcome.
A larger version of the image (Afternoon Walk) can be seen in my gallery:
http://www.renderosity.com/mod/gallery/browse.php?username=DustRider
Thanks in advance!
