Sat, Jan 25, 9:21 AM CST
Subject: Fur creation
rintronato ( ) posted Fri, 01 January 2010 at 11:16 AM · edited Fri, 10 January 2025 at 12:45 PM
I'd like to know if there is a way (or a plugin) that allow what Shave and a Haircut for Maya does, i.e. coloring hair using the follicle or underlying mesh texture.
Thanks
pjz99 ( ) posted Fri, 01 January 2010 at 12:18 PM
You could try plugging the map into the Root_Color, Top_Color and Specular_Color inputs of the Hair shader in the materials room, although I'm sure this will take a lot of finessing and experimentation.
My Freebies
pjz99 ( ) posted Fri, 01 January 2010 at 12:35 PM
After a quick test, short answer, yeah this kinda works.  A shame you can't control distribution or thickness of hairs with a map.
My Freebies
pjz99 ( ) posted Fri, 01 January 2010 at 12:39 PM
Here's another with a very contrasty black and white map (some transmap or other).  Note you have to set the color values for each of the channels on the hair shader to WHITE, they will be RGB multiplied with whatever is on the map.
My Freebies
Acadia ( ) posted Fri, 01 January 2010 at 5:03 PM · edited Fri, 01 January 2010 at 5:04 PM
Try this thread.  There are tutorials for all kinds of things, including fur.
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2722867
The RDNA links are broken, but if you go towards the end of the thread I have reposted them.
rintronato ( ) posted Sat, 02 January 2010 at 4:09 PM
 Thank you folks, very much appreciated !
