Thu, Nov 28, 9:17 PM CST
Subject: hair pieces not staying with skull cap
Believable3D ( ) posted Wed, 30 December 2009 at 5:15 AM · edited Mon, 25 November 2024 at 6:41 AM
Okay, this is odd. I've been working on dynamic hair, and it all seems good when I save - it appears that the various hair groups are parented to the skull cap. However, not so, I guess.... when I load the hair and parent the skullcap to my figure, I'm having troubles with piece of hair staying behind when I move the figure.
I can't figure it out, because when I view the hierarchy, everything looks right.... all the hair groups are ordered underneath the skullcap.
This is happening in both Poser Pro 2010 beta and Poser 8.
I'd imagine it was simply a bug, but ... I don't seem to have the problem when I use dynamic hair that I've purchased. ... Although when I move there can be a delay before the hair moves, and when I hit save the hair visually flies off the head to its original position, but returns to the proper spot when the save is finished.
BTW - I'm parenting the skullcap to the head. That is correct, right?
______________
Believable3D ( ) posted Wed, 30 December 2009 at 1:38 PM
I was reading the manual (yeah, I know - shock, hey?) and it occurred to me that this could happen if the hair groups got locked. Wondered if I had done so accidentally. Unfortunately, no such luck....
______________
lululee ( ) posted Fri, 01 January 2010 at 11:42 AM
Hi believable 3d,
Are they coming loose after you manually reparent them.
I have had problems with the parenting not holding after they are saved and reloaded but when I reparent them manually it usually holds.
cheerio
lululee
Believable3D ( ) posted Fri, 01 January 2010 at 1:26 PM
Hi lululee. Thanks for responding.
Yes, I've tried reparenting (multiple times, because that's what made the most sense to me), but still no luck. But it's only happening with the hair I created, not with purchased hair, so I'm wondering if P8 glitched the save process to begin with.
I bought a 1.5 TB external drive yesterday; I'm gonna try moving all my external runtimes off of my computer to give it some breathing room and see if my Posers function better.
______________
lululee ( ) posted Fri, 01 January 2010 at 4:13 PM · edited Fri, 01 January 2010 at 4:17 PM
Attached Link: Fur-(Nudity)
How odd. maybe it is a Poser 8 glitch. I know that all of my prop parenting is going haywire in PoserPro and PoserPro 2010 when saved to the library but it is fine when reparented manually. I have no problems with it as a figure. I just created an image with some fur clothes I am working on. The bra, wrist and panty are figures with material zones that i put fur on. They are holding very well. Maybe you could convert yours to a figure. cheerio lululee
Believable3D ( ) posted Fri, 01 January 2010 at 4:29 PM
Thanks, lululee... that sounds promising. I'll have to look up how to do that. Haven't converted props to figures yet. Hopefully, that will do the trick.
______________
lululee ( ) posted Fri, 01 January 2010 at 5:01 PM
If you have Wardrobe Wizard, (which comes with Poser8) it will convert a hair prop to a figure.
cheerio
lululee
Believable3D ( ) posted Fri, 01 January 2010 at 5:35 PM
Ah, thanks for the tip.
______________
Plutom ( ) posted Fri, 01 January 2010 at 6:29 PM
Have you tried going to the hierachy menu and moving the skull cap etc to the head (similiar to conforming).  When parenting can you get to the head or is it just the figure?  Jan
Believable3D ( ) posted Fri, 01 January 2010 at 11:12 PM
I'm a little unclear on exactly what you're asking... but the skull cap is parented to the head.
______________
lululee ( ) posted Sat, 02 January 2010 at 7:43 AM
Also, are you making your hair with material zones?
I make mine with the material zones.
Take a look at the scullcap for the Dixie hair.
If you are not sure how to add the material zones let me know and I will post some screen shots.
cheerio
lululee
Plutom ( ) posted Sat, 02 January 2010 at 8:59 AM
Quote - I'm a little unclear on exactly what you're asking... but the skull cap is parented to the head.
I shouldn't have mentioned conforming (has absolutely nothing to do with parenting-couldn't edit that out).  Yes to your question, that what I was asking.
lululee ( ) posted Sat, 02 January 2010 at 9:26 AM
believable3d,
Is the skullcap coming unparented or is the"hair" flying around/
cheerio
lululee
Believable3D ( ) posted Sat, 02 January 2010 at 3:44 PM
lululee, I add material zones when I do the hair groups, as the grouping editor provides that option in the Hair Room (at least - that's the only place I've used the grouping editor, to be honest).
"Is the skullcap coming unparented or is the"hair" flying around"
Well, it's odd, because in some cases the whole kit and kaboodle seemed to be staying in original spot when the figure moved. But at least with the instance that started this thread, I assume the skullcap stayed in place since at least some of the hair groups stayed stuck on top of the head (which makes no sense at all to me; I can't imagine what could be different between the different groups).
Anyway, I copied my files to my new drive last night. I'm running a defrag now, but that will take several hours. So I'll work on my home renovations this aft. Maybe I'll get a chance to work on this later and see if it works better once the computer is cleaned up... I just hope I don't have to start all the work over from scratch.
______________
Believable3D ( ) posted Tue, 12 January 2010 at 4:20 AM
Well, this is a weird one.
I have always parented by selecting the prop and using the top horizontal menu via Object > Change Parent. That supposedly works, as verifiable by the Hierarchy window etc. And it's worked for all the other props I've used. But not for my dynamic hair, even though the skull cap I used as a base is a merchant resource and doesn't have the problem by itself.
Anyway, just now for the heck of it I tried setting the parent on the Properties tab of the Parameters palette.
And whaddaya know - it actually seems to work!!!
But why? Shouldn't both methods have the same result?
And what must I change in the file in order for it to parent properly on load?
______________
Believable3D ( ) posted Tue, 12 January 2010 at 4:23 AM · edited Tue, 12 January 2010 at 4:27 AM
Hm. It only seems to work properly if the skullcap is set to visible (I want it off by default; I only want the dynamic hair groups showing.)
That is a bug, surely?
EDIT: but at least this gives me a workaround, as I can leave the skullcap visible and make it transparent in materials. That won't affect render times as long as "Visible in Raytracing" is unchecked, right?
______________
PhilC ( ) posted Tue, 12 January 2010 at 6:09 AM · edited Tue, 12 January 2010 at 6:11 AM
Saving a group of props as a single smart prop does not work. The parenting between the props gets saved but the parenting to the base figure gets lost. The solution is to save the combined prop as a smart prop then edit the PP2 file to reinstate the parenting to the figure.
Open in a text editor.
Search for "UNIVERSE"
The full line will be:-
parent UNIVERSE
change it to:-
smartparent head:1
Believable3D ( ) posted Tue, 12 January 2010 at 12:16 PM
Thanks, Phil. That is surely a bug.
______________
coltrace ( ) posted Tue, 12 January 2010 at 6:13 PM
Maybe Poser7 wasn't that bad..?
What happens if you delete the stray ones...?
Or maybe with all that work, Believable, you'll find it's your own ..:) !
