Mon, Feb 10, 5:44 PM CST
Subject: Help with "Parameter Dials"
azimakberali ( ) posted Tue, 05 January 2010 at 11:19 AM · edited Mon, 10 February 2025 at 5:42 PM
I just created a simple Poser figure. (not an easy task!) I created the bones and grouped it in the Setup Room and adjusted the joints using the Joint Editor. So far so good. Everything seems to be twisting, turning and bending well. Now my question is this, how can I create a Parameter dial which will bend two or three body parts together? Like the "Grasp" dial on the hand of the Standard Poser Figure which makes all the fingers and the thumb, bend together. I want to create a similar dial for my character's hands so that I can make all his fingers bend together without having to adjust each fingers parameters individiually. Is it possible to create such a dial? If so, please explain to me how. Thank you so much :-)
PhilC ( ) posted Tue, 05 January 2010 at 11:35 AM
Those are hard coded into Poser. Easiest way is to copy the channels from an existing figure. If you have not already got it get this free CR2 editor by John Stallings from:
http://tech.groups.yahoo.com/group/PoserTECH/files/
Open your figure's CR2 file in the left hand pane.
Open the P4 male CR2 in the right hand pane.
Scroll to the hand actor.
Expand to see the channels.
Copy the Grasp, Spread and thumb grasp channels over to your new figure.
Later Poser figures use ERC code which is different so don't be confused by that.
lesbentley ( ) posted Tue, 05 January 2010 at 11:53 AM
Note also, that for the grasp dials to work the finger joints need to follow the standard Poser naming convention for the actors, and probably need to use the same rotation order.
markschum ( ) posted Tue, 05 January 2010 at 11:58 AM
You can use ERC. Thats creating a master dial which will affect the existing bend dials on the body parts.
You can get some details ERC Download Page there.
