Mon, Dec 23, 11:22 AM CST
Subject: How Do I Make Use of OBP File?
Enivob ( ) posted Sun, 15 November 2009 at 7:51 AM · edited Mon, 23 December 2024 at 10:44 AM
Hi All,
I have Bryce 6.0 and I downloaded a obp file from sharecg. I am using Windows and the icon for the obp seems to be associated with Bryce. But I can not figure out how to use the file? Bryce will not open, merge or import obp files. I have double clicked it and Bryce complains it is not a valid file. But I have downloaded several different models from sharecg and they all fail to open. I can't believe they are all broken files.
How do I make use of this file type?
Thanks!
ThunderStone ( ) posted Sun, 15 November 2009 at 8:30 AM · edited Sun, 15 November 2009 at 8:31 AM
For obp files, (psst... it's an **ob**ject **p**reset file for Bryce), it has to be placed in the preset/objects folder of Bryce; or use the Preset Manager within Bryce for that as shown above.
Hey Bryster, Can we make this reply into a stickie or a FAQ?
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
TheBryster ( ) posted Sun, 15 November 2009 at 8:36 AM
Forum Moderator
There is a text explaination of this in the FAQ already.
bobbystahr ( ) posted Sun, 15 November 2009 at 9:13 AM
Attached Link: Bryce Artist Guide
Bryster...I find nada tutled FAQ...Could you be referring to the DAZ Guide...I've linked it here for navigation impaired users
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
TheBryster ( ) posted Sun, 15 November 2009 at 9:22 AM
Forum Moderator
From the FAQ...*
Bryce Object File-Click the small arrow on the right of where it says CREATE and then click import, select the file(.obp, .obj)*
bobbystahr ( ) posted Sun, 15 November 2009 at 10:10 AM
Uh, Chris...a link to the FAQ would be handy...I have no idea where the heck it is.. ...
I see a sound
TheBryster ( ) posted Sun, 15 November 2009 at 11:51 AM
Forum Moderator
It's right under the word 'Coordinators' at the top-left of this page.
http://www.renderosity.com/mod/forumpro/showforum.php?forum_id=107&show_faq
bobbystahr ( ) posted Sun, 15 November 2009 at 12:45 PM
D'oh...I thought you meant a Bryce  FAQ so I looked all over the Bryce Backroom and Sub Communities pages...thanks man.. ...
I see a sound
goofygrape ( ) posted Mon, 16 November 2009 at 12:14 AM
I really think the question was how to get it in Bryce?poss wrong but what the heck.
Speaking of OBP files how do you get one that you made out of Bryce to give others?
TheBryster ( ) posted Mon, 16 November 2009 at 3:16 AM
Forum Moderator
*Speaking of OBP files how do you get one that you made out of Bryce to give others?
*Create your object.
Create new catagory in the Bryce create dropdown.
Save/add your object.
Go to the Objects folder in the Bryce folder.
Your new object/obp will be in the catagory you created.
Send to others, boyfriend, girlfriend, give one to your mom.
Enivob ( ) posted Mon, 11 January 2010 at 9:38 PM
More help for Byce impaired user please.
I have downloaded "Damaged Engine.obp" from sharecg.com. I unzipped the file and placed the obp file in folder "C:Program FilesDAZBryce 6Presets". I click on create and nothing shows up, I just see a bunch of black squares. I restart Byce, the same thing.
TheBryster ( ) posted Tue, 12 January 2010 at 7:02 AM
Forum Moderator
You can place the OBP anywhere and browse for it using the IMPORT option in the create catalogue drop-down.
skiwillgee ( ) posted Tue, 12 January 2010 at 8:41 PM
Bryster,  it might be explained that "import object" in the "file" drop down menu is not the same or correct step you are describing by using the import that is in the "Create" GUI menu.  It is two different animals.
It confused me for the longest time also.
TheBryster ( ) posted Wed, 13 January 2010 at 7:00 AM
Forum Moderator
I'll see about making a tut for this.
TheBryster ( ) posted Wed, 13 January 2010 at 8:49 AM
Forum Moderator
Bryce uses a particular kind of object file called .OBP If you wish to add an .OBP file to your Create Catalogue then you need to import it following these instructions. There are other ways, but for the purposes of this tut I'll stick to the 'one at a time' method. If you have downloaded an .OBP object make sure you have unzipped or unrar-ed it (if necessary) and that you know where it is. You can place it anywhere you like on your hard-drive.
Load up your version of Bryce - this works for all versions.
Look to the top of the work place and you will see 3 tags. CREATE - EDIT - SKY&FOG
Next to each of these is a small and barely visible triangle.
Click the triangle next to the CREATE tag.
This opens your OBP catalogue. If you haven't got any objects in your catalogue or at least in the sub-catalogue you can see, there will be nothing but black squares on it. If you have got objects you will see them. Black squares simply mean that the locations are empty. If they are white then you have problems which I won't go into here.
At the bottom of the catalogue you will see the following tags: ADD DELETE IMPORT EXPORT.
Click on the IMPORT tag. (White arrow)
This will bring up a browse box and you can use this to locate your .OBP object.
Select your .OBP object and it will appear in one of the black boxes!
You can now select that box by just clicking on it and then clicking on the tick mark (Red Arrow)on the far bottom right.
Your new .OBP object will appear on your workplace ready for use.
bobbystahr ( ) posted Wed, 13 January 2010 at 9:46 AM
*"". I click on create and nothing shows up, I just see a bunch of black squares. I restart Byce, the same thing."
*This seems like a new install of Bryce which has never had the content installed yet to me...have you run the content .exe files which came with your version, or should have been downloaded at the same time, as Bryce was. That should fill up the black squares in the Create Menus except for the User ones.. ...
I see a sound
Enivob ( ) posted Tue, 26 January 2010 at 1:23 PM
Thanks, I guess I'll have to run that additional installer. I am completely new to Bryce and did not realize I needed two installs.
