Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Huh, it occurs to me that I can use Firefox to re-download MS Internet Explorer 8 (even though IE itself cannot download IE, go figure) and re-install it. Since this seems to have broken Poser 8 I guess I'll give that a try.
Surprisingly, that seems to have fixed it. Well even a busted clock is right twice a day!
I'm contacting SM support as well but I thought I'd ask here:
Since maybe yesterday night, Poser 8 fails with the following message in the Library window:
FAULT Detected!
[FaultEvent fault=[RPC Fault faultString="HTTP request error" faultCode="Server.Error.Request" faultDetail="Error:[IOErrorEvent type="ioError" bubbles = false cancelable = false eventPhase=2 text="Error #2032"], URL:http://127.0.0.1:11530/apps/lms/api.py"]messageId="E986DC5F-331C-3282-08E9-7318984E4C72" type="fault" bubbles=false cancelable=true eventPhase=2] --- Fault Request Info:
op=appConfig
edit: Poser actually doesn't die after this error happens, just the library will not start (almost as bad). I looked at the SM support page for "Library does not start" and I don't think this is the same problem. Also reinstalled Flash for IE, no help.
My Freebies
