Tue, Nov 19, 8:51 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Poser 8 won't start any more, library chokes
pjz99 ( ) posted Wed, 27 January 2010 at 10:09 PM · edited Tue, 19 November 2024 at 6:14 AM
I'm contacting SM support as well but I thought I'd ask here:
Since maybe yesterday night, Poser 8 fails with the following message in the Library window:
FAULT Detected!
[FaultEvent fault=[RPC Fault faultString="HTTP request error" faultCode="Server.Error.Request" faultDetail="Error:[IOErrorEvent type="ioError" bubbles = false cancelable = false eventPhase=2 text="Error #2032"], URL:http://127.0.0.1:11530/apps/lms/api.py"]messageId="E986DC5F-331C-3282-08E9-7318984E4C72" type="fault" bubbles=false cancelable=true eventPhase=2] --- Fault Request Info:
  op=appConfig
  • Not running a firewall
  • Yes my Internet connection is up (here I am on the web page)
  • I am fairly sure my Internet Explorer install is a bit borked, it started to auto-delete cookies at about the same time.
edit: Poser actually doesn't die after this error happens, just the library will not start (almost as bad).  I looked at the SM support page for "Library does not start" and I don't think this is the same problem.  Also reinstalled Flash for IE, no help.
My Freebies
pjz99 ( ) posted Wed, 27 January 2010 at 10:47 PM
Content room won't work either (not that I use it but I thought I'd mention that).
My Freebies
pjz99 ( ) posted Wed, 27 January 2010 at 11:02 PM
Huh, it occurs to me that I can use Firefox to re-download MS Internet Explorer 8 (even though IE itself cannot download IE, go figure) and re-install it.  Since this seems to have broken Poser 8 I guess I'll give that a try.
My Freebies
pjz99 ( ) posted Thu, 28 January 2010 at 1:28 AM
Surprisingly, that seems to have fixed it.  Well even a busted clock is right twice a day!
My Freebies
pjz99 ( ) posted Tue, 02 February 2010 at 3:14 PM
Well this came back.  Guess I can try re-installing IE8 again...
My Freebies
