Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 02 8:28 pm)
Two solutions. 1. Load a standard poser head then export it as an .obj. Be sure when Poser asks to export just the head and eyes. Now import the same .obj file. Now the head and eyes are all stuck together and it is a prop, not part of a figure. Put the head where you want it and replace the helmet with the head prop. Almost done. You can use a morph manager or a text editor to copy the morphs you want on the head. (If you want seperate eyes you need to perform this whole process for each eye.) --- or --- 2. Open the cr2 files for the figure and the head in a wordprocessor. (the head you exported as an obj and then imported back in.) in the cr2 file for you warhammer figure paste all the vertices for the head under the head custom geometry section. and copy the morphs as above. Hope this gets you going...
One warning : If you put the head on a figure you cannot redistribute the mesh, or the CR2 that includes the head. But I think the CR2 trick would work. Suggest you use the obj files in geometries rather than the exported ones. Exported ones tend to have problems with morphs. You may need to regroup the figure, as the geometries obj's tend to spray pieces around. It will be a real trick the first time, then easy, I think.
Hey I was there then, too. But you can embed geometry in the CR2. If you chop off a figures head and stick it in the CR2 then it has the head geometry in it, just like the orginal obj. Morphs and such are fine. They are differences between the original and the final figure and are useless without the orginal geometry. Most people don't put the actual figure geometry in the CR2, but you can. When you attach a prop to a cr2 it saves the actual geometry in the cr2. And some of the suggestions were very similar to that mechanic.
Hi guys. Now for those of you who have them, you might be enjoying my warhammer figures but i'm missing one important detail: HELMETLESS FIGURES! How the heck do i replace the figures head with a poser4 head AND keep it ONE figure. Also, i want the basic morphs on there too. I don't care for moveable eyes though. so those can be part of the head. ANY ideas. --------------------------------------------------------------------------------
