Mon, Feb 3, 6:57 AM CST
Subject: Prop Parenting problems in Poser 8
rik10463 ( ) posted Sun, 14 February 2010 at 11:05 AM · edited Wed, 24 July 2024 at 12:27 PM
Hello all... I'm having an issue in Poser 8 parenting hand props. It seems every time I try to parent it, The item deforms. Doesn't matter which character or which prop I use... they all do the same. Is this a glitch in the program? or is there something I'm missing.
I've been doing it the same way as all the other versions. (position prop/ select parent/ select hand/ inherit bends...)
Any Suggestions?
Thanks
R
markschum ( ) posted Sun, 14 February 2010 at 11:11 AM
I would have said "inherit bends" but you said you looked at that.
Whats with the pant leg in the bottom picture ?
hborre ( ) posted Sun, 14 February 2010 at 11:11 AM
I don't think inherit bends should be in the workflow for a static prop.  Have you tried the parenting with inherit bends off?
LaurieA ( ) posted Sun, 14 February 2010 at 11:17 AM
Yep, turn OFF inherit bends.
rik10463 ( ) posted Sun, 14 February 2010 at 11:48 AM
I've tried it with and without inherit bends. Does the same thing. I've even tried adding a ball as a primative, parenting that to the hand and parenting the prop to the ball. Same issue just slightly different effect.
And the pant leg at the bottom mark, is actually the bow string deforming when I tried bending the wrist, lol
I'm just not having much luck with poser 8. I have 4 different projects that I started that came to an immediate standstill, all for different issues. oh well. That's what post work is for right?
I'm gonna try to get this one done before the holiday is over  lol
thanks,
R
markschum ( ) posted Sun, 14 February 2010 at 12:14 PM
It almost looks like the joint deforms are extending to the parented prop.  I would report this as a bug to Smith Micro. Are you up to date with the service packs for Poser 8 ?
If it is a still picture Just position the bow and dont parent it.
rik10463 ( ) posted Sun, 14 February 2010 at 12:38 PM
I just contacted them about 2 weeks ago about another issue and they sent me the links to the latest updates. I'm guessing I am up to date, but never hurts to check.
