Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 7:46 am)
and in what format is that character exported ???
And what do you mean with character ?? model, texture, 3d obj ..???
IF YOU WANT TO CONTACT BAR-CODE SENT A PM to 26FAHRENHEIT "same person"
Chris
That are you trying to achieve in Photoshop with an obj file? Just curious... I thought Photoshop was more for processing/manipulating image files, not 3D object files...
It works fine, but....if you have a object with several materials (ie the V4 Bodysuit) you are going to get layers for each separate material (like 7 for just the leg alone).
I'm still trying to find a way to paint, and collapse the layers all into one layer and kick it out for use in Poser (There is something I must be missing).
William the Bloody says it works for him, and I believe him!
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
Well, for V4 I'd be using SnowSultan's maps to texture on (see bottom of that page)... no point in re-inventing the wheel. And for the V4 Bodysuit... same solution (see bottom of that page). Or am I missing something here?
That how to turn etc is written in the manual and the pdf of Photoshop.
So that should not be a problem to figure it out by just reading them.....
Quote - it poser model. female character. going from poser to photoshop. got it to photoshop using obj, but in photoshop she turn sideway. plus was hope you could turn her around. beable make her bigger .
Chris
Quote - Well, for V4 I'd be using SnowSultan's maps to texture on (see bottom of that page)... no point in re-inventing the wheel. And for the V4 Bodysuit... same solution (see bottom of that page). Or am I missing something here?
You can do that way for sure, but using Photoshop 3D tools is like DeepPaint or Blacksmith3D-Paint. or BodyPaint from Maxon, only more familiar.
With the flattened UV map where you think something is may not translate well when you have the model in Poser and in 3D. I do 3D versions of the comic book costumes I drew in 2D and well....sometimes we do not get an exact match, especially when you cross seams or if the UV map is not exactly set up symmetrically. Also you can paint where you want to as opposed to trying to match a distance or spot that is not exactly on a vertex or on an edge.
space
Thanks for all the help. just thought you could do it with poser and photoshop. in maya you can export model and turn it all different way in photoshop. what do texture on the model, but want beable to view all around the model. i will do more reading and try what all you have told me. thanks everyone.
Tom
Hi, wanted to know if anyone has exporting poser 6 character to photoshop?I found about poser 7 exporter, but dont find any about poser 6 exporter. any infor be extremely appericate
