Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 01 3:49 pm)
To give an actual example of what markschum said. If you open a MC6 made in P6, the beginning of the file will look like this: {
version
number <span style="color:rgb(255,0,0);">6</span>
<span style="color:rgb(255,0,0);">mtlCollection</span>
Edit it to look like this: {
version
number <span style="color:rgb(0,255,0);">5</span>
<span style="color:rgb(0,255,0);">figure</span>
Now save it to a pose folder with a PZ2 file extension. The simple procedure of changing "mtlCollection" to "figure" converts a MC6 into a classic MAT pose file. But note that there may be new types of nodes in P6 and later versions of Poser that are not supported by P5.
Are you refering to shaders, PakLed? Unless you were to bake them - not sure how you would do that in Poser, but it's possible in DS3Adv - I don't think P5 knows all the nodes, does it?
The nodes were introduced in P5. Very few were added since, notably the AO node.
basically, long story short...if it's an MC6 material in P5, the folder is just blank. Nothing to choose, show's over folks, nothing to see...;)
It does show up in P3do, which I'm using to do the cataloging.
Well, it looks like a PITA, but I may try it, if nothing else, so I can use most of the '4' characters (V4 has 1 or 2 mt5s, etc., but it looks like Girl 4 and Aiko 4 don't)
MC5 still kicks out the jams though...;)
Probably not, but i just wanted to check and see if there's a utility or method for this. I'm cataloging all sorts of stuff under materials that's mc6, which P5 won't see. Should really reduce the size of my runtime, but there's a lot of items I'll have to hand-texture...sigh...;)
Yes, No, or how?
Thanks....
