Photoshop F.A.Q (Last Updated: 2024 Nov 26 6:58 am)
It sounds like you're doing this in Poser, is that correct? *If so, doesn’t Poser allow you to add your own map to different parts of the body in the material lab? In other words, in the material lab, can you add different maps to either shoe? If so, all you need do is make a new map by making a copy of the old one and flipping it and then applying it in the material lab.
You could use the same UV guides (no real need to change it) but make a different texture map for left and right shoe (Making note to keep the position of the decal the same, but mirroring it), and then make sure they have different mats assigned to left and right shoe such that they use the left and right textures. This is probably a lot easier than re-doing the UVs on a model provided it's not too bad in most other regards. (UV mapping can be a real PITA sometimes, and that's even when you have good tools for the job and understand the process.)
I suspect the person making the model expected maps to have textures and color, but not decals - so they cut corners by using a mirror of one model and sharing the same UVs on both. Considering how they assumed the model to be used 99%, this is probably an understandable shortcut too. (And not forgetting the mention in above paragraph.)
Ah... There are still ways to re-assign material zones in some modeling software without having to do a full remap. That's likely to separate the groups for Poser without requiring a full remap. (I know in Wings3D you can re-assign mats on a model and it retains the original UVs.)
One other downside of remapping is that you have to do all the textures and such from scratch all over again. And any other maps for that model using the original UV template will not to work anymore. Whether it's worth it depends on what your goals are.
