Sun, Jan 12, 1:49 PM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 11 12:30 am)
Subject: RT ENCODER
blueblott ( ) posted Mon, 15 March 2010 at 5:33 AM · edited Wed, 25 December 2024 at 9:19 AM
Greetings.
Can any one help out here with RT ENCODER ?
Have downloaded the De-Code version ( Free)
But when I try to run this I  get the error message that it cannot find  NET Framework 2 which it needs to run this software ?
Have checked and yes it is installed....I re-installed just to make sure but RTE still  will
not kick in.
Have been attempting to open up a file which is encoded with this.
Thanks for any advice.
SilverDolphin ( ) posted Thu, 18 March 2010 at 9:56 PM
Hi blueblott,
What operating system are you using and what are you trying to decode.  If it is Vista or Win 7 you may need to temporarily shut down UAC. If not look around for a RT encoder that does not need net framework.
Hope this helps
blueblott ( ) posted Fri, 19 March 2010 at 11:11 PM
Hi Dude 007
Thanks for your reply.
I was trying to decode " Werts "  Horus freebie from ShareCG.
Running XP Pro.
The version 2.01 of RTencoder.
For some reason it kept giving me error message that I had to install Net Framework 2 for it to work. when this was already installed.
However in the end I went back to RTe site and downloaded version  1, and it worked ok if a bit slow.
Damned frusrating at the time though
Many thanks for your interest
SilverDolphin ( ) posted Sat, 20 March 2010 at 11:42 PM
No problem glad it worked out.
