Fri, Dec 27, 8:28 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 27 7:02 pm)
Subject: Antonia - Opinions?
Rogerbee1 ( ) posted Sat, 20 March 2010 at 6:22 AM
BluEcho: Great work!
CHEERS!
amy_aimei ( ) posted Sat, 20 March 2010 at 11:39 AM · edited Sat, 20 March 2010 at 11:45 AM
Laurie A, the dress is really nice.
Does anyone know how to use the dress Laurie A posted as a dynamic clothing in D|S?
BluEcho, I think I better improve the top for more "extreme" movements.  Nice picture!
I think Antonia is more athletic than Victoria, I better make her some activewear.
lesbentley ( ) posted Sat, 20 March 2010 at 12:03 PM · edited Sat, 20 March 2010 at 12:13 PM
(click image for larger view)
amy_aimei,
I have had a quick look at the BeachVolleyballTop, and the specific problem on the shoulder straps that happens in the LegUp pose with the hands behind the head. It seemed to me to be a joint parameter problem, so I played around until I found a fix. The problem with changing a JP, is that in fixing one problem, it is easy to create others. After a quick check I can't see any new problems, but I do not have time for really thorough testing of the fix.
[edit]
In the Joint Editor I changed the 'Static A' parameter in the 'Swing' channel of the Left Shoulder to a value of 139.735 (see image above) ,  then used Symmetry Left to Right to copy the PJs to the other shoulder.
rjjack ( ) posted Sat, 20 March 2010 at 12:06 PM
Quote - Laurie A, the dress is really nice.
not possible, the dynamic clothes of DS are different, you need some specials tools to create a dynamic clothe for DS, currently only Optitex or DAZ own these tools
Fisty ( ) posted Sat, 20 March 2010 at 12:14 PM
Quote - not possible, the dynamic clothes of DS are different, you need some specials tools to create a dynamic clothe for DS, currently only Optitex or DAZ own these tools
Which annoys me to no end...  I'm gonna be the first PA to jump on that when they finally release the creator softwear/plugin and I'll make DS and Poser version of everything...  I wish they'd get off their butts.  >.<   I can't even use DS dynamics right now anyway since I use 64 bit.. and I refuse to install 32 bit just to use the one piece of DS dynamic I've bought.   I may install 32bit ds3-free on my laptop for testing purposes and convert that one item to obj so I can use it in Poser.
sazzyazzca ( ) posted Sat, 20 March 2010 at 12:29 PM
I do set up everything in DS, and because I generally end up tweaking poses, use the Poser Format Exporter script to save the tweaked pose. Then I run the simulation in Poser using my tweaked pose, export the resulting obj of the clothing item, and then import the obj into DS.
Very nice work everyone! Thanks for the new goodies :D
LaurieA ( ) posted Sat, 20 March 2010 at 2:04 PM
That so thoroughly sucks that D|S doesn't treat dynamic clothing in a similar way as Poser :o(.
Rogerbee1 ( ) posted Sat, 20 March 2010 at 2:05 PM
Some jeans and a t-shirt wouldn't go amiss.
CHEERS!
WandW ( ) posted Sat, 20 March 2010 at 2:38 PM
Quote - That so thoroughly sucks that D|S doesn't treat dynamic clothing in a similar way as Poser :o(.
Indeed, very poor marketing.  To go this route successfully, they should have made the tools to create dynamic cloth available for free, or for a nominal fee...
Fisty ( ) posted Sat, 20 March 2010 at 2:42 PM
yeah.. I really don't like it..  if the designer program was available, even for a cost, it wouldn't be so bad..  I was excited at first about ds dynamics but the way it's been implimented is not great.
Believable3D ( ) posted Sat, 20 March 2010 at 3:17 PM
Yup. Doesn't make DS dynamics very tempting to the user, either, since you can't just "dynamify" (virtually) any object like in Poser.
______________
lesbentley ( ) posted Sat, 20 March 2010 at 6:41 PM · edited Sat, 20 March 2010 at 6:55 PM
**bagginsbill**
After making the geom injection files for your BBEyes v2, I was having some problems with a dark ring round the iris when rendered in P6, but got distracted by other projects. Someone approached me recently having what seemed to be the same problem in P8.
The issue, if it is an issue, and not some mistake we are making, is a dark ring around the iris.
In the above image, the 'PM:Rim Shadow' node is set to zero. 'Casts Shwdow' is off for the Eye and Eye Cover. This is a P6 FireFly render with Raytracing enabled, and two Raytrace bounces. The texture map is applied to both the Eye and EyeCover.
Is this something we are doing wrong, or an issue with the shader or geometry? Any help much appreciated.
sylki ( ) posted Sat, 20 March 2010 at 7:04 PM
I am dying to get Antonia but I am having trouble downloading her. The page at
http://www.german-3d.com/Antonia_Polygon/index.html . is a bit messed up and I'm not sure which of the two downloads I need..... or is it both? Another problem I'm having is that the download keeps on cutting out on me, I'm not sure if it's my pathetic service provider or not.
Any help would be so great!!
Thanks a lot
Sylvia
sazzyazzca ( ) posted Sat, 20 March 2010 at 7:14 PM
A couple of morphs I did today. I'll upload them tomorrow.
odf ( ) posted Sat, 20 March 2010 at 7:18 PM
sylki: The download button at the top is for the Antonia figure. You can also get her at the link that's shown in my signature. The other download button is for the texture (which you can't get from the other site). I could read the page better when I scaled it down with Ctrl-minus. Apparently the fonts show up larger on some browsers than they were intended to.
I've just started a test download of the texture (which is the larger download) and get around 20 minutes as the expected download time. That can be a problem if your internet connection is not very stable. I suggest you use some application or browser extension that can resume interrupted downloads. If you use Firefox, I recommend the DownThemAll extension.
odf ( ) posted Sat, 20 March 2010 at 7:19 PM
Quote - A couple of morphs I did today. I'll upload them tomorrow.
Nice! :thumbupboth:
sazzyazzca ( ) posted Sat, 20 March 2010 at 7:22 PM
Thank you. :D
I'm having trouble with a nose wrinkle morph though. She kinda needs one of those to make her disgusted expression more accurate.
sazzyazzca ( ) posted Sat, 20 March 2010 at 7:26 PM
Some lash morphs I'll upload tomorrow as well, pointed and outer corner down.
sylki ( ) posted Sat, 20 March 2010 at 7:29 PM
odf: Thank you so much for the help. I am checking out DownThemAll right now. I managed to read the download page properly too, thanks for the advice:-)
I hope that I can manage to download Antonia, she looks so lovely and I am dying to use her. Her joints seem so much smoother than Vicky's and her armpits look perfect:-)
Thanks again
Sylvia
sazzyazzca ( ) posted Sat, 20 March 2010 at 7:29 PM
A couple of morphs to make the outer and inner corners shallower, also available tomorrow.
odf ( ) posted Sat, 20 March 2010 at 8:00 PM
By the way: after exchanging some IMs with PhilC, I've decided to finish the hands and feet first, after all. It seems like quite a few people have been picking up Antonia recently, and I think WW support would be a great thing to have. So I'm making finalizing the body geometry and joint setup a priority now, which needs to happen before Phil can do his magic.
I've started to work on a better hand shape yesterday. It's mostly just smoothing the fingers a bit, but also fixing some small issues at the joints and giving the thumb some more love. When that's done, I'll make it available as a full-body morph so you guys can test it. I might do a similar thing with the toes if I decide to fine-tune their shapes as well. I'll also do some work on the JPs, mostly for the toes, but maybe also some little things for the fingers, and possibly add JCMs for the toes.
sazzyazzca ( ) posted Sat, 20 March 2010 at 8:19 PM
WW support would be awesome!
SaintFox ( ) posted Sat, 20 March 2010 at 8:26 PM · edited Sat, 20 March 2010 at 8:27 PM
*To go this route successfully, they should have made the tools to create dynamic cloth available for free, or for a nominal fee...
Hmmm... so far I have not a lot hope about it as the software that is able to creat DS dynamic clothes is made by the company that creates the dynamic clothes for DAZ. Why should they want to sell a tool to other creators that at the moment gives them a kind of monopole?
**I've just started a test download of the texture (which is the larger download) and get around 20 minutes as the expected download time. That can be a problem if your internet connection is not very stable.
I did not think about that... may it be useful to break up the texture set into two or more pieces?
Oh and: NICE expressions!!! They match the "see how far we can bend this doll" renders :laugh:
I'm not always right, but my mistakes are more interesting!
And I am not strange, I am Limited Edition!
Are you ready for Antonia? Get her textures here:
The Home Of The Living Dolls
odf ( ) posted Sat, 20 March 2010 at 8:36 PM
Quote - *
Well, on the other hand I've done a test with DownThemAll: started a download, killed the browser, restarted the browser and resumed the download. That worked like a charm, which I think means that your server must support that kind of thing. For someone with a flaky internet connection using a tool like DownThemAll really makes much more sense than us splitting the files into tiny portions, in my opinion. Or am I missing something?
[/offtopic]
SaintFox ( ) posted Sat, 20 March 2010 at 8:40 PM
No - my opinion as well. As soon as you have the files on your harddrive it is so much nicer to have it all-in-one.
Digital-Lion ( ) posted Sat, 20 March 2010 at 8:46 PM
@sylki
40,2 MB for the textures in 20 sec. at 1829,7 Mb/s speed    -  you have a slowly connection ;-(
but I can split it for you !
I wanted S/M-light - so I installed Windows......
Life can be such a crap - you just have to try hard enough!
LaurieA ( ) posted Sat, 20 March 2010 at 8:46 PM
Quote - By the way: after exchanging some IMs with PhilC, I've decided to finish the hands and feet first, after all. It seems like quite a few people have been picking up Antonia recently, and I think WW support would be a great thing to have. So I'm making finalizing the body geometry and joint setup a priority now, which needs to happen before Phil can do his magic.
Perhaps you could put in a good word to EvilInnocence too? Some of us use CrossDresser rather than WardrobeWizard ;o).
sazzyazzca ( ) posted Sat, 20 March 2010 at 8:57 PM
Good idea! I use both, but some people prefer one over the other.
Different lips shapes, including smoochie lips, also available tomorrow.
Michael314 has also kindly given permission to use his morphs in a spawned morph, so I'll be uploading my elf type morph as well. Like my others, feel free to fix, tweak and otherwise  use them as you see fit.
Faery_Light ( ) posted Sat, 20 March 2010 at 9:43 PM
I do wish it would stop sending me to the main forum or market place when I reply and click submit!
As I tried to post...
This doll is getting better and better.
Now I need to finish my MAT files and do promo sets.
I'll need beta testers for two different texture sets so do I just post them on the developer's site or ask in the forums?
sazzyazzca ( ) posted Sat, 20 March 2010 at 9:57 PM
Morphs are uploaded. There are 4 elf type morphs with subtle differences to the eyes only. There will also be a psd file at sharecg to darken the inside of the nostril area tomorrow. Now to finally get back to eyeliners and shadows. She's so much fun to play with I get distracted. LOL
sazzy_antonia_eye_morphs.zip [
sazzy_antonia_elf_morphs.zip](http://www.4shared.com/file/245732538/fff03232/sazzy_antonia_elf_morphs.html) [
sazzy_antonia_lash_morphs.zip](http://www.4shared.com/file/245732950/ae6be4e2/sazzy_antonia_lash_morphs.html) [
sazzy_antonia_nose_morphs.zip](http://www.4shared.com/file/245733076/c2537fbf/sazzy_antonia_nose_morphs.html) [
sazzy_antonia_expression_morphs.zip](http://www.4shared.com/file/245733356/f223a364/sazzy_antonia_expression_morph.html)
lesbentley ( ) posted Sat, 20 March 2010 at 10:07 PM
odf,
Quote - So I'm making finalizing the body geometry and joint setup a priority now, which needs to happen before Phil can do his magic.
Cough... cough... I hate to bring this up, as you have more than enough on your plate already, but I feel that the tongue is a also something else that needs attention, before the rig and geometry is finalised. I don't feel that the current two part tongue works very well (Have you tried poking it out through her lips then bending it?). I feel that there are issues with the rigging, grouping, topology, and perhaps UVs.
It is (yet again) too late at night to go into details. I will try to say more tomorrow. I just wanted to foreshadow the fact that I am likely to become an unbearable pest over the tongue in the next few days.
Then again, perhaps the tongue is not relevant to WW, but I thought I had better raise it now, rather than wait till it is too late.
Believable3D ( ) posted Sat, 20 March 2010 at 10:15 PM
I was just going to say: not relevant to WW. And there, you said it.
I think that finalizing the body geometry and rigging is a great idea, if it means that PhilC (and perhaps EvilInnocence) will provide support sooner. I'm sure that the relative paucity of clothing is going to hold a few people back from using Antonia; and if the changes for the foreseeable future would just be in the head, it wouldn't be a big deal (I presume).
______________
odf ( ) posted Sat, 20 March 2010 at 10:58 PM
Quote - @sylki
Do you mean 1829 Kb/s and 175 seconds? Or if it's really 20 seconds, you probably meant 1829 KB/s. 😉 Which would be 8 times as fast as my top download speed here with ADSL and about 40 times as fast as what I get on weekends.
Unicornst ( ) posted Sat, 20 March 2010 at 11:38 PM
Quote - Morphs are uploaded. There are 4 elf type morphs with subtle differences to the eyes only. There will also be a psd file at sharecg to darken the inside of the nostril area tomorrow. Now to finally get back to eyeliners and shadows. She's so much fun to play with I get distracted. LOL
Are these inject or morph target? And if morph target, can someone explain how to do that in Studio?
odf ( ) posted Sun, 21 March 2010 at 12:06 AM
I asked Phil specifically about the tongue, and he confirmed that it's not relevant.
Cage ( ) posted Sun, 21 March 2010 at 12:52 AM
Quote - I asked Phil specifically about the tongue, and he confirmed that it's not relevant.
Wait... you mean I won't be able to use WW to convert my conforming tongue-warmer to Antonia?  :crying:
Really exciting to hear that Wardrobe Wizard support is in the works.  :woot:
And thank you, **sazzyazzca, for the morphs!
All right, why am I stuck in bold face type, now?  Huh.
cyberscape ( ) posted Sun, 21 March 2010 at 1:36 AM · edited Sun, 21 March 2010 at 1:40 AM
Attached Link: The Antonia Collection
The Antonia Collection is finally here! Hope you all like this texture set as much as I liked making it!
I plan to add expansion packs to this as time allows.
Now I can get on with checking out all of the goodies that everybody else has been making!
Sorry about the large file downloads. Happy rendering!
AMD FX-9590 4.7ghz 8-core, 32gb of RAM, Win7 64bit, nVidia GeForce GTX 760
PoserPro2012, Photoshop CS4 and Magix Music Maker
...and when the day is dawning...I have to say goodbye...a last look back into...your broken eyes.
cyberscape ( ) posted Sun, 21 March 2010 at 1:47 AM
One thing to add about the Antonia Collection, rather important...
it does NOT contain any morphs! Only a navel gone magnet. And a buttload of textures!
The face in the promo pics is the result of Cage's Morph Transfer Script, coupled with V3's head morphs. Hence, the reason why the face morph can't be shared :(
odf ( ) posted Sun, 21 March 2010 at 1:58 AM · edited Sun, 21 March 2010 at 1:58 AM
cyberscape: That looks great, and now I've finally signed up for ShareCG because of that set. :laugh: Because of the size, I will do the downloading overnight, though.
Believable3D ( ) posted Sun, 21 March 2010 at 2:00 AM
Thanks a lot, Cyberscape! very interested to take a look.
______________
odf ( ) posted Sun, 21 March 2010 at 2:29 AM
Here's a 'Before & After' of the hand shape. I'll attach the injection pose to my next post.
odf ( ) posted Sun, 21 March 2010 at 2:32 AM
file_449906.txt
Here's the new shape as a partial body morph. Remove the '.txt' from the filename, then unzip as usual. Please be aware that I haven't yet tested or adjusted the bends to the new shape.
sylki ( ) posted Sun, 21 March 2010 at 6:49 AM
I managed to download everything, thank you everyone for all the suggestions:-)  but when I load her into Daz Studio her eyes and teeth are too far forwards from her face:-( Any suggestions?..... Sorry to be a pest!!!!:-)
Sylvia
odf ( ) posted Sun, 21 March 2010 at 6:58 AM
Quote - I managed to download everything, thank you everyone for all the suggestions:-)  but when I load her into Daz Studio her eyes and teeth are too far forwards from her face:-( Any suggestions?..... Sorry to be a pest!!!!:-)
Sylvia
This problem has been mentioned before, and if I remember correctly, the solution was to upgrade Daz Studio to the latest version.
sylki ( ) posted Sun, 21 March 2010 at 7:02 AM
This is the second time I'm sending this!
I managed to download everything, thanks everyone for the suggestions, hut when I load Antonia into Daz Studio her eyes and teeth are too far forward on her face! Any suggestions? This is waht it says in the log.
Sorry to be a pest!
Sylvia
Warning: No binary morph file for useBinaryMorph on line 2901 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 2920 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 2939 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 2958 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 2977 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 2996 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 3015 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 3034 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 3053 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 3072 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 32786 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 32805 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 32824 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 32843 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 32862 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 32881 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 32900 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 32919 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 32938 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 32957 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 32976 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 32995 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33014 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33033 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33052 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33071 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33090 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33109 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33128 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33147 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33166 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33185 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33204 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33223 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33242 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33261 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33280 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33299 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33318 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33337 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33356 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33375 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33394 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33413 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33432 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33451 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33470 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33489 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33508 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 33527 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 39807 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 39826 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 39845 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 39864 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 39883 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 39902 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 39921 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 39940 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 39959 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 39978 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 60295 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 60314 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 60333 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 60352 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 60371 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 60390 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 60409 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 60428 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 60447 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Warning: No binary morph file for useBinaryMorph on line 60466 in C:/Program Files/DAZ/Studio/content/runtime/libraries/character/Antonia/Antonia-122oldUVs.cr2
Imported: Antonia-122oldUVs.cr2
sylki ( ) posted Sun, 21 March 2010 at 7:06 AM
Sorry for the double post but the first one didn't show up until your letter:-(
I'm using the latest Daz3 ...3.0.120! Is there a newer one than this?
Sylvia
WandW ( ) posted Sun, 21 March 2010 at 7:16 AM
It sounds like it's looking for a PMD file, but there isn't one in the archive.  I 'm not at my Poser machine, but I don't recall any issues with the oldUV version in Poser...
The current version is 3.0.1.144 , available here:
download.cnet.com/DAZ-Studio/3000-6677_4-10717523.html
edgeverse ( ) posted Sun, 21 March 2010 at 7:18 AM
I just tried this collection in Poserpro and it works great. thanks for the collection. I am gonna test it in DS now.
3D Digital Comics & Art/My homepage
http://www.edgeversemedia.com
sylki ( ) posted Sun, 21 March 2010 at 7:20 AM
Hi WandW
Do I really need this version? Its such a huge download!
Sylvia
odf ( ) posted Sun, 21 March 2010 at 7:22 AM
According to the DAZ website, 3.0.1.144 is the latest.
By the way, I tried loading the figure after removing all the 'useBinaryMorph' lines from the cr2, but got the same effect (Version 3.0.1.135). I don't know that those lines do anything useful, but they don't seem to cause the problem, either.
