Vue F.A.Q (Last Updated: 2024 Sep 17 9:46 am)
Make sure your movement gizmo has the G selected, instead of the L (as in Local).
It's known to happen that when you have a group of different objects, each one with its own axis, and you try to move the group with L activated, each individual object will move in different directions.
Hope that helps.
Rutra,
I checked each group, and randomly checked some of the objects within each group. I went to the Display tab, and looked at the gizmo coords, and each show global. However, even when I load the grouped object into an empty scene, there are animation "trails" leading off behind the object.
I solved the current problem by recreating the objects in place with the starship models, (a real pain) but it would still be helpful to know how to solve this issue for anything I might do in the future. Also, does the "G" show up anywhere other than in the Display menu? Generally, I have gizmos off, and only use the standard tool--rotation, resize, move, with the x, y, z buttons, etc?
Hi,
I've been working on creating an animated Enterprise for some small animations. Most of the models I've imported do not have usable (in Vue anyway) bussard objects for lighting and movement animation. I spent several hours creating an animated Vue object, testing the lighting, and the rotation of the blades, trying to get the right look. However, when I load the saved Vob into a new scene to add it to the ship model, evrything kind of flys apart when I try to run the animation preview. Does anyone know what setting I need to apply either to the Vob itself, or when I load it into a new scene, so that all the effects stay with the center of the object.?
On a similar note, there's a great model by Dennis Bailey of the Enterprise in Blender, but I haven't been able to find the right export settings to get it to import into Vue. I printed out a short Obj export tutorial online (for Blender), but the settings still do not seem to allow Vue to import the object. I'm still using Vue Esprit 6---I've had luck in the past using Vue 5 to import (then save the vob for Vue 6), but no luck with this particular model.
thanks
