Sat, Dec 28, 1:08 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 28 11:34 am)
Subject: Antonia - Opinions?
Digital-Lion ( ) posted Thu, 25 March 2010 at 9:44 AM
 I'm shopping in downtown now ...................  ;-)
LG
I wanted S/M-light - so I installed Windows......
Life can be such a crap - you just have to try hard enough!
                    The Home Of The Living Dolls
lesbentley ( ) posted Thu, 25 March 2010 at 1:08 PM · edited Thu, 25 March 2010 at 1:19 PM
bagginsbill,
Quote - I'm going to change those freebie sections to real Wiki sections. This allows them to be edited separately. I'm a noob to Wiki, but it seems it is hard to avoid two people simultaneously editing the document. If it is broken up into sections it is easier to deal with.
Sounds like a very good idea!
Quote - I see somebody added a section for links to Antonia pictures. That's a bad idea, IMO. As time progresses, there will be hundreds of those, and I don't want to deal with scrolling through all that just to see stuff I want to get. If you want to make an Antonia Image page, that makes sense to me. Sort of like a facebook wall for Antonia.
I am the guilty party, and I think you are right. I have now put the images on a separate page.
Quote - It was LesBentley.
I think these sort of conflicts are inevitable when two people are editing the page at the same time. I have had some of my changes trashed too. This is only the first day of the Antonia wiki, I'm sure there will be less conflicts when things settle down after a few days.
P.S.
I did not see any edit conflict warnings, but perhaps that is because I don't know where to look for them.
Digital-Lion ( ) posted Thu, 25 March 2010 at 1:21 PM
 Attention!!
I'm back now ...................
Rogerbee1 ( ) posted Thu, 25 March 2010 at 1:27 PM
Honestly, I can't leave you lot alone for five minutes, LOL!
CHEERS!
Faery_Light ( ) posted Thu, 25 March 2010 at 1:40 PM
I'll post some of my freebies as soon as I finish setting up my new Web site.
I had to transfer all my pages manually so I could edit all the links within each page...sigh.
Then I'll need to know if you all would rather use the wiki or have me set up a special site for all the Antonia freebies.
If you want tu have a special site, i'll need to find out how to let other folks do their own uploads.
lesbentley ( ) posted Thu, 25 March 2010 at 1:56 PM · edited Thu, 25 March 2010 at 1:57 PM
BluEcho,
I think it would be good if you can set up a site for Antonia freebies.
sylki ( ) posted Thu, 25 March 2010 at 2:44 PM
Here are the links to my two Antonia images, if someone would be kind enough to put them on the Wiki for me.
http://www.renderosity.com/mod/gallery/index.php?image_id=2034597
http://www.renderosity.com/mod/gallery/index.php?image_id=2035201
Thank you so much
Sylvia
bagginsbill ( ) posted Thu, 25 March 2010 at 2:52 PM
Quote - Here are the links to my two Antonia images, if someone would be kind enough to put them on the Wiki for me.
Thank you so much
Sylvia
I did it.
I put these two in a different style than the others, using the square brackets. Nobody really needs to see the URLs, do they? The way all the others are listed takes more space than needed.
sylki ( ) posted Thu, 25 March 2010 at 2:59 PM
Thank you very much, you're  a sweetie:-)
Sylvia
lesbentley ( ) posted Thu, 25 March 2010 at 3:27 PM · edited Thu, 25 March 2010 at 3:31 PM
bagginsbill,
Have you seen the post linked below, and do you have any thoughts on it?
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2753785&page=211#message_3619121
I'm getting a dark ring around the iris of the BBEyes (P6). Probably something simple that I am neglecting to do. I never have been very good with materials.
bagginsbill ( ) posted Thu, 25 March 2010 at 3:58 PM · edited Thu, 25 March 2010 at 3:59 PM
Hmm. I downloaded your zip and loaded what you assembled. Works fine for me, but I'm in Poser 8. So it's not misconfigured. Perhaps this is a P6 problem.
I rendered this with PM:Rim Shadow=0, like you did.
I'm wondering about raybias. I think its meaning has changed. P6 was not very good at refraction.
I haven't seen anybody else besides you and me post any renders with the eyecover. If they did, they didn't mention it. Why is that? Do they only work for me? Or is practically nobody interested?
We need some more datapoints.
bagginsbill ( ) posted Thu, 25 March 2010 at 4:01 PM
This is with Rim Shadow = .7. Nothing like as dark as you're getting. it's not the rim shadow.
lesbentley ( ) posted Thu, 25 March 2010 at 4:10 PM · edited Thu, 25 March 2010 at 4:21 PM
bagginsbill,
My first thoughts on the issue where that it must be something to do with the Rim Shadow. I'm not so sure now. Even if I delete the Rim Shadow node, I still get the problem. I may be wrong, but I seem to remember that odf posted a P6 render that did not display this problem.
bagginsbill ( ) posted Thu, 25 March 2010 at 4:29 PM
Deleting the rim shadow node will not remove the rim shadow - it will maximize it. That isn't the node that does the rim shadow. That is the node plugged into the node(s) that make the shadow. By deleting it, you're setting it to 1, or maximum because somewhere else the maximum value is multipied with this value, by virtue of being connected to it. Connecting a node to an input multiplies that node with that input. When you delete this node, the input is left with its full value, instead of being modulated by the PM:Rim Shadow node.
Just so we're clear, I'll say again that the rim shadow effect is not a real shadow. It's node math. You also said you made sure cast shadows is off for the cover, which is good. Otherwise it really will cast a shadow, but not just a rim shadow - a full shadow of the entire cover.
As an experiment, move the eye cover forward, away from the iris, by about .1 inch and see what it looks like. If the dark ring goes away, this is a ray bias problem.
You could also try just rendering the eye cover in front of a white card.
lesbentley ( ) posted Thu, 25 March 2010 at 5:20 PM · edited Thu, 25 March 2010 at 5:24 PM
bagginsbill,
Sorry for the delay in responding, I'm working on a very old low spec system that takes an age to do anything, even a spot render. Your suggestion of moving the eyecover forwards, does indeed remove the dark ring.
Now I need to find settings that will allow the eyecover to render correctly without moving the cover.
SaintFox ( ) posted Thu, 25 March 2010 at 5:25 PM
BB, may you give some informations about your light set-up? I had issues with a kind of ring - more a shoadow that appeared around the edge of the eye-cover. One issue we found here where some double "knots" (I am not sure how this is called in eglish, I am talking about the points where the polygons meet) that Leo deleted for me. Then we tried some different positions for the eye cover and what worked best was pushing the eyecover a little bit into the sclera. But there is still a little kind of shadow left. Maybe the lights I use cause this, maybe my render-settings - I am not sure.
So it would be helpful if you can tell me the light's settings you've used for your render that looks flawless to me, maybe even your render-settings. I've made my renders in PoserPro and PoserPro 2010.
Test renders will follow in a moment.
I'm not always right, but my mistakes are more interesting!
And I am not strange, I am Limited Edition!
Are you ready for Antonia? Get her textures here:
SaintFox ( ) posted Thu, 25 March 2010 at 5:26 PM
This is what I've got when rendering the eye "out of the box".
SaintFox ( ) posted Thu, 25 March 2010 at 5:28 PM · edited Thu, 25 March 2010 at 5:28 PM
This is the eye with the few corrections on the eyecover, the materials are the same as before except the bump. Here I replaced the procedural settings with a bump map I 've created from the sclera's texture.
fabiana ( ) posted Thu, 25 March 2010 at 5:28 PM
where is the zip that Bagginsbill and Les are talking about? I want to try that thing of the RimShadow :)
ODF: are there any possibility to know if the joints will be "official" soon? I am doing an update in a clothing set for v4 and would like to include an Antonia version but if the joints are still in develop then I must wait... some data?????
fabi
Fabi @FKDesign
One in some place under Southern Stars...
Don't tell me that I am wrong if I say I saw pointed ears this morning, in my mirror... they are there.
bagginsbill ( ) posted Thu, 25 March 2010 at 5:41 PM · edited Thu, 25 March 2010 at 5:45 PM
I have to hit the road for a couple hours.
Meanwhile, here's a link to where I posted a very common light set I made and use all the time.
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3617788&ebot_calc_page#message_3617788
I'm pretty sure the eye looks good with this set.
bagginsbill ( ) posted Thu, 25 March 2010 at 5:44 PM
odf ( ) posted Thu, 25 March 2010 at 5:46 PM
Online Now!
Hi Fabiana! The joints are now safe for anything but turtlenecks, gloves and socks.
I'm very excited about all the activity on the wiki, which I hadn't quite expected. Great job, everyone! I agree with lesbentley's assessment that things will probably settle down a bit after the first frenzy hours or days, and conflicts will be less likely. Still, it is certainly a good idea to keep the editing guidelines that BB posted at the top of this page in mind.
I'll add a status section that I'll try to keep as up-to-date as possible, so that my answers don't get lost in the thread anymore. I'll add some technical information and maybe some "general history" as well. But not now, as I have to be off to work in ten minutes. :laugh:
bagginsbill ( ) posted Thu, 25 March 2010 at 5:46 PM
Quote - BB, may you give some informations about your light set-up? I had issues with a kind of ring - more a shoadow that appeared around the edge of the eye-cover. One issue we found here where some double "knots" (I am not sure how this is called in eglish, I am talking about the points where the polygons meet) that Leo deleted for me. Then we tried some different positions for the eye cover and what worked best was pushing the eyecover a little bit into the sclera. But there is still a little kind of shadow left. Maybe the lights I use cause this, maybe my render-settings - I am not sure.
Those double knots were not double. I placed a very tiny edge ring around the cover to force it to match the slope of the sclera.
I'm wondering - did you render with smoothing enabled? Turn that off on the covers.
lesbentley ( ) posted Thu, 25 March 2010 at 5:49 PM
fabiana,
The files to inject the BBEye geometry into Antonia "LB BBeys TEST-03.zip" are in the 'Files to Work On' section of the antoniadevelopers site. I do have an updated version with some slight improvements, but have not gotten round to uploading it yet.
There is also the original prop version of the eyes, that can be downloaded from BB's site. The prop can be used on any figure, but must be set up manually (quite a bit of work):
http://sites.google.com/site/bagginsbill/free-stuff/bbeye
odf ( ) posted Thu, 25 March 2010 at 5:52 PM
Online Now!
Fabiana, if you don't have access to the developers site, send me an IM (or mail to Antonia Polygon at GMail) with your email address. The same goes for anyone else who has made (and shown) items for Antonia and doesn't yet have access to that site.
SaintFox ( ) posted Thu, 25 March 2010 at 6:25 PM
*I'm wondering - did you render with smoothing enabled? Turn that off on the covers.
*I tried it all: Smooth enabled on eye and cover, disabled on the eye cover, disabled in the render settings... no difference at all. Regarding light settings I tested several options from a single white Infinite light to several IBL-sets. *
At the moment I am fighting with DAZ Studio to check the material settings sazzyazzca posted, later I will check the eyes with your light sets.
fabiana ( ) posted Thu, 25 March 2010 at 10:00 PM
thank you Les and  thank you ODF. still didn´t looked at that but will send the IM now :)
just to win time till tomorrow that I will be at home again from this short trip :)
fabi
Fabi @FKDesign
sazzyazzca ( ) posted Thu, 25 March 2010 at 11:05 PM
I made a minor mistake on the eyeliners because I didn't take the lacrimals into account and textured a bit over them on the layers. This is what happens when you're tired and rushing to finish something. Sigh.... I'll fix it in a few days when time permits. In the meantime,  you can just erase where it covers the lacrimals. Sorry about that.
SaintFox ( ) posted Thu, 25 March 2010 at 11:27 PM · edited Thu, 25 March 2010 at 11:28 PM
sazzyazzca: I've tried out the DS-materials and they work and look good!! At the moment I am trying my luck with Antonia's textures in combination with the human surface shader. If I end upwith something usable I'll post the material settings. I am very much hoping that I understood the Human Surface shader right... I am not redistributing it when creating a matpose from my results, right? The user still needs to pre-apply it or at least to own it to use it... As you seem to have more clue of DAZ Studio's material secrets you may be the one who can answer this.
Fisty ( ) posted Thu, 25 March 2010 at 11:32 PM
it will apply the textures but the textures have to be in there for it to find just like a pz2.. no copywrite issues at all with DS matfiles.
sazzyazzca ( ) posted Thu, 25 March 2010 at 11:38 PM · edited Thu, 25 March 2010 at 11:40 PM
My understanding (and I might be wrong) is that if you make DS mat files using the HSS, the user actually has to have it in order for the mat files to work as the creator intended them to. I think essentially you're just distributing the settings. I did mine using just the default DAZ shaders because not everyone has HSS, but the HSS  sure does look nice if you can master it. :)
Fisty ( ) posted Fri, 26 March 2010 at 12:00 AM
Yes, the user has to have HHS installed for DS mats made with HSS to work.   However - because it came with the Elite skins almost everyone has it.
It is possible to make HSS mats save them, duplicate the folder and edit the files to use the uber surface that is included with DS3.  DS3 free version can read and use them that way.
To do that you have to save them as .ds or .dsa, saving .dsb is not editable in a text editor.
To make the conversion search for: support/omnifreaker/shaderDefinitions/surface/omHumanSurfaceDef.ds
and replace it with: support/DAZ/Uber/shaderDefinitions/surface/omUberSurfaceDef.dse
SaintFox ( ) posted Fri, 26 March 2010 at 12:00 AM
So far my results look not too bad (well - as long as I don't compare them with the VSS-shaders rendered in PoserPro... but I don't do this as to me it seems a bit like matching apples with pears). I don't want to run into any troubles but would like to use this shader as, from the discussions I read, many "hardcore" DS users own at least one of the Elite textures - that's how I've got it but I dislike the Elite bump maps and specular maps (with dark freckles in the bump maps and "glittery" specular maps) and so I did not use them again so far.
All the Elite texture-sets come with the HSS and so many people may have it. Most of all I can make use of the specular maps I've added for the classic Toni Maps.
Fisty ( ) posted Fri, 26 March 2010 at 12:05 AM
You can use the specular maps with regular DS settings too.. just plug it into the specular strength or color channel.  (don't plug it into glossiness channel, it does really funky things)
Unicornst ( ) posted Fri, 26 March 2010 at 12:28 AM
Quote - Yes, the user has to have HHS installed for DS mats made with HSS to work.   However - because it came with the Elite skins almost everyone has it.
No, sadly, not almost everyone. Some are too low on income to ever be able to get it and some (gasp) didn't care for the Elite skins. Guess which I am? grin But I do so appreciate you giving advice on how to make them usable for DS3 Free version.
SaintFox ( ) posted Fri, 26 March 2010 at 12:33 AM
Well - I very much understand and know what it means to be close on budget! And for all those fellows that do not own the HSS we have alreasy sazzyazzca's settings that look really fine! Maybe she doesn't mind to create all the needed settings for the different eyebrows as well!?!
Unicornst ( ) posted Fri, 26 March 2010 at 12:36 AM
Quote - Well - I very much understand and know what it means to be close on budget! And for all those fellows that do not own the HSS we have alreasy sazzyazzca's settings that look really fine! Maybe she doesn't mind to create all the needed settings for the different eyebrows as well!?!
Which is why I appreciate you so much. All of you. You all think of the ones on a budget as well as making items the best you can. And that best is very fine!
sazzyazzca ( ) posted Fri, 26 March 2010 at 12:38 AM
Control+ double-click brings up a dialog box that allows you to choose to ignore the maps and just apply the shader settings, so you can use it with any textures you have loaded. :)
Bea ( ) posted Fri, 26 March 2010 at 1:39 AM
So DS3 free can read shaders that call the UbS even though it is not included with it? Or is it?
Fisty ( ) posted Fri, 26 March 2010 at 1:59 AM
It is included, the ability to apply the base shader is disabled afaik after the trial period but matfiles that call it still work.  Much like the shader mixer, the free version can read it but can't develop it.  I don't know if you can change settings in the surface tab after applying it with ds3free.  At least this is what NielV has said and I trust him.  I don't have a free version of 3.* installed anywhere to do it myself.  I usually use 2.3 with or without HSS for my development.
Bea ( ) posted Fri, 26 March 2010 at 2:05 AM
No I don't have a free version to test it either :) but thanks :)
SaintFox ( ) posted Fri, 26 March 2010 at 2:29 AM
In fact I have a free version here but it never stopped crashing out of sudden and I am simply tired of all the bugfixes and upgrades as more as my Visual C++ was overwritten when upgrading.
So unfortunatly there is no way for me to check if the materials will work without HSS - but as said: What I wanted to do is creating at least a rough impression of what you will get in Poser with the non-VSS version. And as the DAZ Studio default material settings have no velvet, subsurface scattering and such using HSS seemed the only way to me to achieve this look.
Bea ( ) posted Fri, 26 March 2010 at 2:35 AM
Its not the HSS its the UbS that comes free with DAZ 3 Advanced. If the shaders call the HSS they will not work unless the HSS is on the computer.
Fisty ( ) posted Fri, 26 March 2010 at 11:39 AM
Correct, Bea.. which is why I include both.. since changing a line of code twice to make it usable by a ton more people is an easy thing to do.  They won't be usable by people who can't run 3.* and don't own HSS though.. need regular basic DS 2 mats for that... which I also make if it's a commercial product.
Now.. that being said, you can get very nice results out of the basic surface tab and they render really fast. SS is bloody slow.
Which texture are you trying to make mats for and where is it living right now?
Bea ( ) posted Fri, 26 March 2010 at 6:17 PM
Fisty we are updating our shaders that we used to sell at 3DC. We are including UbS files as well :) as the HSS files but I wasn't sure if they would work in the free DAZ3 as well as the advanced.
Faery_Light ( ) posted Fri, 26 March 2010 at 6:38 PM
Hi,
I'm just popping in to get some info off the pages to included on Antonia's freebie site.
At present I am trying to set it up with a site builder to start off and later, edits as needed, in an html editor.
I'll let everyone know when it's ready. :)
Faery_Light ( ) posted Fri, 26 March 2010 at 8:57 PM
Where did my last post go? 😕
I tried to use the site builder but that flopped. :rolleyes:
So now I am doing it in an html editor and psd layers for css if I get it right.
Would anyone like to contribute some gorgeous promo shots for the home page?
One standing pose taller than wide, one sitting and maybe one laying down would be nice.  :biggrin:
SaintFox ( ) posted Fri, 26 March 2010 at 9:35 PM
Did you find a solution on how to upload things?
SaintFox ( ) posted Fri, 26 March 2010 at 10:04 PM
How much time do I have for the promos? :laugh:
Faery_Light ( ) posted Fri, 26 March 2010 at 10:08 PM
I use the file manager or my ftp program for uploading.
No hurry on the promos yet.
I'm just now setting the place holders in place and can add them when you have them ready. :)
I'm thinking it may be a good idea if I can add someone as an administrator to help keep the site for her going.
I'll use a sub-domain for her pages so that can be done.
Then is anyone has a little time and wants to work on it with me, we can figure it out.
