Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
In the absence of a visual, I have to assume that what you expect is a shadow isn't.
For example, if you light a figure from behind only, the face is dark, not because of shadows but because it doesn't point towards the light.
Whoa. OK I've never seen that. You should contact SM.
Is anyone else having an issue with shadow only renders in Poser Pro 2010? I had an obvious shadow in the original render but I wanted boost it a bit so I did a shadow only render and it only rendered the last third of the image with a shadow. Anyone else having issues or is it just a weird glitch, it did it twice on the same scene. Thanks
