Sat, Feb 1, 9:05 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 6:51 am)
Subject: Shadow only render in Poser Pro 2010 problem
Ghostofmacbeth ( ) posted Sun, 28 March 2010 at 9:42 PM · edited Tue, 21 January 2025 at 12:13 AM
Is anyone else having an issue with shadow only renders in Poser Pro 2010? I had an obvious shadow in the original render but I wanted boost it a bit so I did a shadow only render and it only rendered the last third of the image with a shadow. Anyone else having issues or is it just a weird glitch, it did it twice on the same scene. Thanks
ice-boy ( ) posted Mon, 29 March 2010 at 12:04 AM
can you show the render?
bagginsbill ( ) posted Mon, 29 March 2010 at 7:04 AM
In the absence of a visual, I have to assume that what you expect is a shadow isn't.
For example, if you light a figure from behind only, the face is dark, not because of shadows but because it doesn't point towards the light.
Ghostofmacbeth ( ) posted Mon, 29 March 2010 at 10:28 AM
I will show a render when I get home and it isn't that, there is a definite cast shadow coming from the figure's chin area but it does not show in the shadow only, same in the stairs and other areas. It also doesn't show any of the AO that is in the scene, except in that one part of the image.
Ghostofmacbeth ( ) posted Mon, 29 March 2010 at 6:26 PM
OK, here is the render where you can see the shadows
Here is the shadow only render
Ghostofmacbeth ( ) posted Mon, 29 March 2010 at 6:27 PM
Here is the zdepth render since it is doing it too.
bagginsbill ( ) posted Mon, 29 March 2010 at 6:48 PM
Whoa. OK I've never seen that. You should contact SM.
