Carrara F.A.Q (Last Updated: 2024 Sep 29 9:32 am)
Hello,
I don't think you need to make a C code. Text feature, deformers and behaviors in Carrara should do the work fine, even better.
Holyforest,
Hundreds of shaders for
Carrara
Quote - Analog
----the movie file is faulty---not in an acceptable current format.Brian
PS--This should be on yourother thread-----sorry
Hi Brian,
This is a different animation compared to the other two, but if a moderator feels like it should be in the other one, you can merge the threads.
The video is encoded in MPEG 2 format, so either the download got corrupted or you dont have the codec to display it.
This is the Codecs that I install on my machines and seem to handle a good percentages of any video that I download from the net.
http://www.free-codecs.com/download/codec.htm
Holyforest:
Scrollers are usually pretty long, I think I might have to create a few hundred text objects group them and apply the right type of deformations to give it that look.
Brian:
MPEG-2 is DVD format and also for TV Broadcast, the reason for the Large size is, the video is no compressed as much as MPEG4, but once the final project is complete, I will share it on YouTube, DIVX AVI Format and possibly MPEG4.
Here's one that actually seems simple:
If that's not easy-peasy, I'm not certain what is.
Now I'm not sure if the text itself can be made to scroll, but this gives a decent start. I guess you could have one long line of text and move it on one axis to get an appropriate effect. (I'm not sure if Carrara limits text length, so that'll need some testing.)
Oh be careful about editing the text while the modifier is applied. Seems to cause an odd bug that keeps tweeners changes from being applied. (You'll get an error dialog first though.)
I'll post a vid link after my example renders.
Attached Link: http://www.youtube.com/watch?v=tnjv0eARquo
Here's the vid. So I did get something that works without going outside of Carrara. Yet like I said, there may be some limitations I haven't ran into because this is just a quickie done for a demonstration.Your friendly neighborhood Wings3D nut.
bwtr: I blinked when playing that last one, what was it supposed to do?
Pauljs75: You are a Genius!!! :)
First a little about my attempt. before reading your post.
I read through the manual trying to understand the wave modifiers, and did play with the phase settings, but now looking at your method I realize the importance of setting the oscillation in the tweener.
Oh an one other thing to note. I tried to network render my scroll text scene and I got weird artifacts on the actual text itself almost like Video Tearing. I played around with the Network Render settings but it didnt make much of a difference.
I used a standard font, with standard metal shaders applied using one of the included 2 light systems.
I'll re-do everything using your method and display the results. :)
Genius? Dunno about that. It's just something in Carrara I actually remember messing with before. When the process is easy to knock out like that, it's hard to not just give it away.
I know some plugins make artifacts akin to what you describe. But that usually involves cases where you get a reflection of a reflection. (ie: Sparrowhawke's otherwise nifty experimental falloff shader does this.) I still keep these plugins, but move them into a folder outside of the Carrara directories for times when they cause problems. Also in certain lighting conditions (like non-moving direct light in an outdoor scene), it might be good to set the lighting for static scenes under render settings or the background gets noise that looks like video snow.
As to other things, who knows? Could be compression or something like that too. I usually just render to frames for animation and use VirtualDub & Xvid, since they're free and present few problems. (PC only though. I dunno what is comparable to vdub on the Mac side, sorry.)
Thanks for the Input Pauljs75 Now I'm wondering if it has something to do with the ground plane and text shaders being reflective.
All my animations are being rendered to .BMP or .PSD files, which I process in Sony Vegas afterwards.
I dont have any plugins, just a Vanilla Carrara Pro 6 installation.
I'm not much of a coder, but with all the capabilities in Carrara, is there a way I can generate a Sine Wave Scroller text?
Here is an example of what Sine Scroller text looks like:
http://www.youtube.com/watch?v=8jNsIQpBgHA
The example you see would have been programmed in C or Machine Language with a 8 or 16 color Bitmap for the fonts.
