I would check that the multi-threading is checked on the PC. If it is, then to check if the system sees both processors. Press Control-alt-delete or right click on the task bar, bring up the task manager. Select Performance and it should have a CPU Usage History section. If it has 2 graphs there then the OS see's both processors. if you do things you should see most activity in one, but should see some in both.
You might also need to check your network configuration. Sometimes firewall and router settings get in the way. This also means that settings which work one way may not always work the other way in network directionality.
Of course if I'm confused a little and you're just talking about one computer rather than connecting the two of them... There should be a tick box lower down under render settings that says "multi-threaded" that needs to be checked on. The render settings panel does scroll, depending on screen size.
pauljs,
I'm not using rendernode.
I'm talkin about the standalone mode.
Holyforest,
Hundreds of shaders for
Carrara
Quote - I would check that the multi-threading is checked on the PC. If it is, then to check if the system sees both processors.
Xerxes,
Multi-threading is on.
The Mac Intel doesn't need any additional configuration to work perfectly, that's what's strange.
Holyforest,
Carrara
Quote - I had a similar problem, I had forgotten to create a rule to allow WIndows 7's firewall to communicate with my internal networks IP Range.
How may I do that?
Thanks
Holyforest,
Carrara
Perhaps I would need to contact DAz support?
Holyforest,
Carrara
Quote - Hello Holyforest,
in the render room under miscellaneous there
there is a checkbox "enable multi threading"
is that enabled?
Yes, it's enabled...
Very strange.
I had a normal rendering with the two tiles before I did a complete Vista reintsall.
Now that doesn't work anymore!!???
Holyforest,
Carrara
Hello Faba :)
This is an example of images renered on PC: http://www.renderosity.com/mod/gallery/index.php?image_id=2041867&user_id=34800&np&np
and on the Mac : http://www.renderosity.com/mod/gallery/index.php?image_id=2033745&user_id=34800&np&np
Technicaly, there is no difference except the "tiles" problem.
I just sent a bug repport to Daz...
Wait and see.
Holyforest,
Carrara
There might also be some setting you have to tweak under the task manager. But I couldn't be 100% certain, since I'm still on XP here. But supposedly there have been some changes to processor management and not all software handles it automatically.
Yes, some investigation is needed, but I've got very low skill with Vista...
Holyforest,
Carrara
Quote - I would check that the multi-threading is checked on the PC. If it is, then to check if the system sees both processors. Press Control-alt-delete or right click on the task bar, bring up the task manager. Select Performance and it should have a CPU Usage History section. If it has 2 graphs there then the OS see's both processors. if you do things you should see most activity in one, but should see some in both.
I saw both that processors are active.
I'm upgrading to Windows Seven...
Wait and see ;)
Holyforest,
Carrara
Windows Seven is installed.
Problem is solved with Carrara rendering.
A great mystery !!!
Holyforest,
Carrara
Quote - At least you have it back working now. Very good!
Yes , that's the good news :)
Holyforest,
Carrara
Hello,
I've got a Mac Intel core duo 2 ghz, OS X 10.5.8.
I've got a PC Intel core duo 2 ghz with Vista.
I've got Carrara 7 pro running both on the Mac and the PC.
When rendering with the Mac, I've got 2 tiles - a yellow one and a pink one.
When rendering with the PC, I've got only one yellow tile and of course a slow rendering.
Any idea about what's wrong with my configuration on the PC?
Thank you,
Holyforest,
Hundreds of shaders for Carrara
