Mon, Feb 17, 5:57 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Carrara Free Stuff here.
Subject: Strange phenomenon ;)
holyforest ( ) posted Mon, 12 April 2010 at 12:52 PM · edited Sat, 08 February 2025 at 8:06 AM
Hello,
I've got a Mac Intel core duo 2 ghz, OS X 10.5.8.
I've got a PC Intel core duo 2 ghz with Vista.
I've got Carrara 7 pro running both on the Mac and the PC.
When rendering with the Mac, I've got 2 tiles - a yellow one and a pink one.
When rendering with the PC, I've got only one yellow tile and of course a slow rendering.
Any idea about what's wrong with my configuration on the PC?
Thank you,
Holyforest,
Hundreds of shaders for Carrara
Xerxes0002 ( ) posted Mon, 12 April 2010 at 1:13 PM
 I would check that the multi-threading is checked on the PC.  If it is, then to check if the system sees both processors.  Press Control-alt-delete or right click on the task bar, bring up the task manager.  Select Performance and it should have  a CPU Usage History section.  If it has 2 graphs there then the OS see's both processors.  if you do things you should see most activity in one, but should see some in both.
pauljs75 ( ) posted Mon, 12 April 2010 at 2:34 PM
You might also need to check your network configuration. Sometimes firewall and router settings get in the way. This also means that settings which work one way may not always work the other way in network directionality.
Of course if I'm confused a little and you're just talking about one computer rather than connecting the two of them... There should be a tick box lower down under render settings that says "multi-threaded" that needs to be checked on. The render settings panel does scroll, depending on screen size.
Barbequed Pixels?
holyforest ( ) posted Mon, 12 April 2010 at 3:32 PM
pauljs,
I'm not using rendernode.
I'm talkin about the standalone mode.
Holyforest,
Analog-X64 ( ) posted Mon, 12 April 2010 at 10:40 PM
I had a similar problem, I had forgotten to create a rule to allow WIndows 7's firewall to communicate with my internal networks IP Range.
holyforest ( ) posted Tue, 13 April 2010 at 2:51 AM · edited Tue, 13 April 2010 at 2:53 AM
Quote -  I would check that the multi-threading is checked on the PC.  If it is, then to check if the system sees both processors.
Xerxes,
Multi-threading is on.
The Mac Intel doesn't need any additional configuration to work perfectly, that's what's strange.
Holyforest,
holyforest ( ) posted Tue, 13 April 2010 at 2:59 AM
Quote - I had a similar problem, I had forgotten to create a rule to allow WIndows 7's firewall to communicate with my internal networks IP Range.
How may I do that?
Thanks
Holyforest,
holyforest ( ) posted Tue, 13 April 2010 at 10:36 AM
 Perhaps I would need to contact DAz support?
Holyforest,
faba ( ) posted Tue, 13 April 2010 at 10:38 AM
Hello Holyforest,
in the render room under miscellaneous there
there is a checkbox "enable multi threading"
is that enabled?
holyforest ( ) posted Tue, 13 April 2010 at 12:05 PM
Quote - Hello Holyforest,
is that enabled?
Yes, it's enabled...
Very strange.
I had a normal rendering with the two tiles before I did a complete Vista reintsall.
Now that doesn't work anymore!!???
Holyforest,
faba ( ) posted Tue, 13 April 2010 at 12:43 PM
Sounds really strange.
The only other thing I could imagine would be NPR/ draft, but since you compared
the same render on the MAC and the Windows system this cannot be the reason either.
holyforest ( ) posted Tue, 13 April 2010 at 2:52 PM
Hello Faba :)
This is  an example of images renered on PC: http://www.renderosity.com/mod/gallery/index.php?image_id=2041867&user_id=34800&np&np
and on the Mac : http://www.renderosity.com/mod/gallery/index.php?image_id=2033745&user_id=34800&np&np
Technicaly, there is no difference except the "tiles" problem.
I just sent a bug repport to Daz...
Wait and see.
Holyforest,
pauljs75 ( ) posted Tue, 13 April 2010 at 6:56 PM
There might also be some setting you have to tweak under the task manager. But I couldn't be 100% certain, since I'm still on XP here. But supposedly there have been some changes to processor management and not all software handles it automatically.
Barbequed Pixels?
holyforest ( ) posted Tue, 13 April 2010 at 7:32 PM
 Yes, some investigation is needed, but I've got very low skill with Vista...
Holyforest,
holyforest ( ) posted Sat, 17 April 2010 at 6:14 PM
Quote -  I would check that the multi-threading is checked on the PC.  If it is, then to check if the system sees both processors.  Press Control-alt-delete or right click on the task bar, bring up the task manager.  Select Performance and it should have  a CPU Usage History section.  If it has 2 graphs there then the OS see's both processors.  if you do things you should see most activity in one, but should see some in both.
I saw both that processors are active.
I'm upgrading to Windows Seven...
Wait and see ;)
Holyforest,
holyforest ( ) posted Wed, 21 April 2010 at 10:55 AM
Windows Seven is installed.
Problem is solved with Carrara rendering.
A great mystery !!!
Holyforest,
faba ( ) posted Wed, 21 April 2010 at 11:55 AM
At least you have it back working now. Very good!
holyforest ( ) posted Wed, 21 April 2010 at 4:50 PM
Quote - At least you have it back working now. Very good!
Yes , that's the good news :)
Holyforest,
