Sat, Jan 11, 11:05 PM CST
Subject: Dinosaur lost!
Philywebrider ( ) posted Sun, 18 April 2010 at 11:24 AM · edited Wed, 08 January 2025 at 1:04 AM
My computer crashed and I'm tyrying to recoup my files. Can anyone tell me where this dinosaur is sold?
markschum ( ) posted Sun, 18 April 2010 at 11:40 AM
I dont recognise it but DAZ and content paradise both had a range of dinos.
bob1965 ( ) posted Sun, 18 April 2010 at 12:10 PM
More info on the crash, usually the data can be recovered fairly simply as long as you haven't reformatted the HD.
Helpful info would be:
Computer model and brand
HD model number and brand
OS
Descripton of the crash, error msgs and action taken
Philywebrider ( ) posted Sun, 18 April 2010 at 8:11 PM · edited Sun, 18 April 2010 at 8:12 PM
I had put all my data on an external drive. My computer crashed and somehow  the identifier on the drive was erased. The computer no longer "sees" the exterenal drive. I tried several repair places and they said they would" try to fix" the problem for $300 to $500 dollars, but no promises.
I had tried connecting the external drive to another computer, but with no result. I just want to try redown what data I can. I need to use the dino for a project.
I never purchased anything at content paradise so I didn't get it from there. I bought lots at Daz, but I couldn't find it there.
markschum ( ) posted Sun, 18 April 2010 at 8:29 PM
Daz should list all purchases in your account profile. Even stuff that not in the website any more .
Your external drive may have had the usb connection fried. :(   if that has happened you should be able to remove the drive from the external enclosure and mount it in the computer case , even if temporarily to copy files off it.
megalodon ( ) posted Sun, 18 April 2010 at 8:35 PM
Quote - Your external drive may have had the usb connection fried. :(   if that has happened you should be able to remove the drive from the external enclosure and mount it in the computer case , even if temporarily to copy files off it.
Yes, this happened with a couple of my Western Digital MyBooks and I ended up removing the drive. Fortunately the drive was fine and the files were easily accessed. I would try removing the drive and testing it that way first.
pakled ( ) posted Sun, 18 April 2010 at 11:26 PM
hm...I know that Content Paradise had a lot of dinosaurs, back in the day, but the saddle, I dunno.
Philywebrider ( ) posted Mon, 19 April 2010 at 6:03 AM
I found the T-Rex at Runtime DNA. The saddle was from giant snail racing rig.
The USB connection is good, ID thingy is on the external drive,
Thanks everyone.
bob1965 ( ) posted Mon, 19 April 2010 at 6:49 AM
Great you have found the dino.😄
Now on to the problem, as it stands at the moment you have a "brick" containing your data.
You cannot currently access the data.
Do you want to track down and re-install everything you have on the external drive individually or do you want to try to recover the data en masse?
The user's in this hobby tend to be computer literate, many are quite knowledgeable and because of the wide disparity in hardware a broad range of problems has been encountered.
Chances are that someone has experience with the same problem you have so if the pertinent information is supplied there is a good expectation that the problem can be resolved.
What have you got to lose?
WandW ( ) posted Mon, 19 April 2010 at 8:56 AM · edited Mon, 19 April 2010 at 8:58 AM
Quote - I found the T-Rex at Runtime DNA. The saddle was from giant snail racing rig.
Thanks everyone.
An external drive contains a 'normal' harddrive and a USB adapter.  What they are saying is that the problem likely lies with the USB adapter(the Device ID is a property of the USB adapter) , and the drive itself (and your data on it) may be fine.  If this drive is removed and either installed into another adapter/case combination ($20 or so at Newegg), or installed into a computer as a secondary drive (free if you have the cable), the data can be easily retreived.
