Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 3:39 am)
I always use displacement with noise, works nicely. Blend with a clouds or
spots node for varying height.
Wonder if anyone has tried using the new Normal maps in P8? Seems like you
could get some true 3D effects with the blades bending different ways.
Maybe even a waving field of tall grass by animating the colors.
My python page
My ShareCG freebies
www.youtube.com/watch which I was proud of back then
but I thought doing it with nodes might render faster
but this is what I keep getting
the top one is a cloth plane and the bottom is the ground, they keep staying flat
PoserPro 2014, Windows 7, AMD FX-6300 6 core, 8 GB ram, Nvidia
GeForce GTX 750 Ti
You can make an easier grass simply by adding a 'Noise' shader to bump and displacement slot of the ground plane in the MAT room.
dph
I think all the OP's questions have been dealt with already, but it's probably worth pointing out that this is not 'my' shader, it's based on something BB posted a long time ago. If the search function here produced meaningful results I'd post the link to that.
Also note that displacement value = height of grass in whatever units you're working in. I always work in metres. The value in my post in the original thread translates to exactly 2 inches, so I'm guessing that that was what BB originally had in there.
You can apply the shader to anything you want, but I used a Cloth Plane (Hi res square) for the examples I showed. If you have Poser 8, try the shader on round or square high res groundplanes - it works a treat.
PoserPro 11 - Units: Metres
Adobe CC 2017
Here's BB's original post. It also has the settings for doing 'hair' based grass.
EDIT: holy moly, the original post is over 4 years old! I can't believe I've been using this shader and its derivates that long.
Adobe CC 2017
How do I save the material? I can save a scene with the material in it, or I can save a prop, but how do I save the material settings so I don't have to enter them all again manually the next time I want to use the grass texture? The Material library gives me only the option to create a new folder, nothing for the material itself.
Quote - How do I save the material?
Make sure you're in the Material Room. Select the object that has the material applied, and make sure the library window is active (if you're using P8 / PPro 2010). If it's a new, empty folder, click on the bit that says 'empty'; otherwise click on any existing icon in there. You should see the [+] button at the bottom.
Adobe CC 2017
Quote - > Quote - How do I save the material?
That's what confuses me. If I do what you say (I'm using Poser Pro 2010, BTW), all it will let me do is create a new folder. It won't let me save the texture. I just tried it and I got a new empty folder called "Grass" at the end of the process. In (for example) the Figures library you can make a new folder but you can also save a figure - there are three options there: 1. Create new folder (icon with a folder that has a + on it), 2, Add to library (Icon with only a +), and 3, Remove from library (Icon with a -). In the Materials library there is only an icon for Create new folder. It's odd that in the Materials library there isn't even a Remove from library icon, let alone an Add to library one.
It's worth stressing that you can only save mt5 or mc6 files from the Material Room, unlike figures, poses, hair and all the rest that you can save from the Pose Room - the pic shows the differences in the library window.
The [ - ] button shows because I have a material selected in the library. The [ + ] button is there because I've selected the material to be saved.
Adobe CC 2017
I'm in Poser Pro 2010 right now (on my other machine). I'm in the Material Room. I have the grass (single sided square) item selected and see all the shader tree mods I've done. I select the Poser library window. However, all I get at the bottom of the Library window is an icon with a folder and a + symbol over it. That's all. That's why I'm confused. Perhaps there is something funky about my Poser installation? It seems to work fine in most other respects, although certain files cause it to crash. I haven't figured out what the common denominator is with the crash thing but it seems to happen on certain files and not on others, but I suppose it is possible that this is related. Or maybe it's something completely different. I'm using Windows 7 64 bit, 6 gigs of ram (and very glad to get Poser 2010 because of that extra ram - now I can finally use it.)
I have looked through the Library display options and haven't found anything that will toggle extra icons but it doesn't seem like that should be necessary. I think something just isn't working right here.
Oh, forgot to mention (FWIW) - if I select an existing material in the Materials library I get icons for Apply Preset, Add folder, Delete from library, and Add to favorites. But nothing I do ever gives me a single + icon for Add Material. When I select a folder in the Materials library I only get the one icon (add folder) as explained earlier.
Quote - Oh, forgot to mention (FWIW) - if I select an existing material in the Materials library I get icons for Apply Preset, Add folder, Delete from library, and Add to favorites. But nothing I do ever gives me a single + icon for Add Material. When I select a folder in the Materials library I only get the one icon (add folder) as explained earlier.
You should probably submit a bug report to Smith Micro if the + sign isn't showing up for you at all in Poser Pro 2010. I'd also reccommend pestering BillBaggins who wrote the library for Poser Pro 2010.
Two things I do when that happens. First switch to Favorites and then back to the Library sometimes brings the + sign back. If that doesn't work, quit the library and then from the pull down that allows you to view the various parts, select library and it will relaunch. (I am at work so I can't remember the pull down title). But the latter has worked every time for me. It's like the longer I use PP2010, and navigate to various runtimes and so forth the library either has to much to keep track of or runs out of memory. I use the AIR version.
Gary
Attached Link: http://renderosity.com/mod/forumpro/showthread.php?thread_id=2799669
[http://renderosity.com/mod/forumpro/showthread.php?thread_id=2799669](http://renderosity.com/mod/forumpro/showthread.php?thread_id=2799669)
Does any know how cspear did the grass on this what obj did he use
I tried asking in that tread, but I guess no one is watching that one
what I am talking about is in the thread I have listed
Thanks Steve
PoserPro 2014, Windows 7, AMD FX-6300 6 core, 8 GB ram, Nvidia GeForce GTX 750 Ti
