Sun, Feb 9, 3:09 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 09 1:04 pm)
Subject: how can I make a poser man built of hand writing?
storyos ( ) posted Fri, 23 April 2010 at 1:16 PM · edited Tue, 04 February 2025 at 8:40 AM
Hi all,
I am wondering if it is possible to create a character that would be built out of handwriting? as if his texture would be made of words?
thanks alot.
ockham ( ) posted Fri, 23 April 2010 at 1:31 PM
This may not be anywhere near what you're thinking of.....
Apply the text as an image to the figure's texture, then make a negative image and
apply the negative image to the transparency.
My python page
My ShareCG freebies
Ghostofmacbeth ( ) posted Fri, 23 April 2010 at 1:32 PM
I did this a while ago for a card game and it worked pretty well. Just do a transmap on the body and head and write things, the trick is to match scale and deal with distortion. You also might want to have some sort of edge to the surface or not go 100& black.
Example: http://www.tradecardsonline.com/img/cards/shadowfist/569/big/101.jpg
storyos ( ) posted Fri, 23 April 2010 at 2:38 PM
thanks so very much for both answers. it seems this might be possible after all. but,
i am not sure how do you do things such as :
  1. applying image to the figure's texture
  2. apply image to the transparency
    or
  3. do a transmap on the body and head and write things.
i will try to read about how to do that - but if you have any quick tips i would be very happy to read them... :-)
markschum ( ) posted Fri, 23 April 2010 at 8:08 PM
you would start with a copy of the figures , or the clothes uv template or seam guide. Those are available for DAZ products on the product page for download.
That template shows you how a painted texture will be applied to the figure. Just load it to a paint program and create an empty layer to draw your text on. delete the template layer , and then save your picture.
Apply the texture in the Poser material room . if you need to start from scratch its right click, new node , 2d , image map . click on the file name area to select your image.  Connect the image node to the Diffuse input by clicking and dragging from the top left corner of the image node to the diffuse node. The icon is plug and socket.
same thing for transparency map , except transparency is grey scale with black being transparent and white being visible. Greay shades are partial. Plug that into the transparency node .
estherau ( ) posted Sat, 24 April 2010 at 7:40 AM
 there was one exactly as you are looking for but female called newsie who was in the MP hear at renderosity.  she was made of newsprint, and she was for V3 and I think V3 textures work on M3 so you could just buy it and make a male character out of M3.
Love esther
MY ONLINE COMIC IS NOW LIVE
