Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Yeah that's the problem.. I don't want to have to delete the figure (and apply all the morphs, conforms, cloth simulations etc) again. Right now I'm solving it by simply saving to new files very frequently, so I don't have to redo -too- much each time it happens.. :)
Are you using Poser 8 too, or another version?
I posted this same question over at daz. one of the replies gave .cr2 technical advice
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
I haven't had it happen with V4, but it happens occasionally with M4 using Poser 7.
The best & most beautiful
things in the world cannot be seen nor touched... but felt in the
heart.
Helen Keller
My
Gallery
My
Freebies
My
Store
In the past I've had this problem.
I opened the scene file and found that there was a glitch -- there was no reference to the hip geometry. So I copied and pasted from the abdomen (changing abdoment to hip) and all was good.
actor hip:1
actor abdomen:1
storageOffset 0 0 0
geomHandlerGeom 13 abdomen
you want to change this to
actor hip:1
storageOffset 0 0 0
geomHandlerGeom 13 hip
actor abdomen:1
storageOffset 0 0 0
My bad! The hip object is where the problem is. Not sure whether this will help anyone else but I found out what happened in my case and that V4 in that particular scene of mine is now FUBAR.
As an explanation: I was working on the scene in P8. Since P8 takes a long time to come up I left it up and running while I went to take a nap. When I got up and only after I'd resaved the scene did I notice the problem (I'd had V4, everything touching her and all lights affecting her all set).
I tried loading the scene into P7 but had the same problem. A bit later I noticed that the lights on my sound system were flashing. That's an indication that there was a power fluctuation. Not one bad enough to reboot my computer but possibly bad enough to mess up files that were in memory.
I expect the following to be true although I can't prove it:
If, as I have, you saved the corrupted file over your last good save the only answers are to rebuild the scene or at least reload everything associated with V4 or find a way to edit and correct the pz3 file.
Anyone know of an editor that can edit and save a pz3 file? I really don't want to have to redo all the posing for V4.
I can share my experiences on this. I find that when I load the file, if the hip on V4 is gone, it's best to just reload or REVERT immediately. I have not found the need to toggle the genitals On/Off switch, and usually the reload of the scene fixes it. However, if you don't check for V4 missing hip and then do some work and SAVE the scene, you've probably messed V4 up. You can reload and reload the scene ater that, and it won't matter. The only fix then is to do what AnAardvark says above.
Be aware that sometimes after the fix AnAardvark mentions is used, the hip comes in distorted. I find the Waist Width morph can be manipulated to "almost" fix this.
I've had this problem probably 100 times in the last year, and wish it could be fixed, but Daz calls it a Poser problem and Smith Micro calls it a third party figure issue.
Good luck
Hey, I'm wondering if anyone has run into this issue.
At some point while working on a certain project, Victoria 4's entire hip part is gone. There's a hole where it used to be.. Since I have clothes over her, I usually don't notice until it's late, and then the whole project is ruined, since I use dynamic cloth simulations.
Has anyone else had problems where entire body parts simply disappear? (It's not hidden)
Thanks
Grappo
