Sat, Feb 8, 9:25 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 08 9:05 am)
Subject: What is this?
spod ( ) posted Wed, 28 April 2010 at 12:15 PM · edited Sat, 08 February 2025 at 9:13 AM
PPro 2010 leaves a file with the extension "icache" -What does this file do? Is. it worth  keeping ?
IsaoShi ( ) posted Wed, 28 April 2010 at 1:11 PM
What is the full file name? What folder is it in? More clues, please! :O)
spod ( ) posted Wed, 28 April 2010 at 1:18 PM
Every scene file I render. the file is put in the directory where I keep scene files.
FrankT ( ) posted Wed, 28 April 2010 at 1:40 PM
are you using IDL ? - looks like it might be the irradience map data judging by the name
My Freebies
Buy stuff on RedBubble
nruddock ( ) posted Wed, 28 April 2010 at 1:48 PM
At a guess those files are caching the Irradience data, and as such are temporary files.
spod ( ) posted Wed, 28 April 2010 at 1:52 PM
Yes. I use IDL. I surmised they might be associated with Irradiance Cache. Will  keeping them speed rendering?
FrankT ( ) posted Wed, 28 April 2010 at 3:06 PM
depends on whether or not Poser reuses the irradiance data or not.  I don't have it so I couldn't say for sure but no doubt someone will have an answer
My Freebies
bagginsbill ( ) posted Wed, 28 April 2010 at 3:40 PM
Speaking only theoretically, I don't think it re-uses the cache. If it did, there would probably be an option to clear it, and I wouldn't see red-dot IDL pre-calc a second time with no scene changes.
lmckenzie ( ) posted Thu, 29 April 2010 at 8:51 AM
I don't know if Poser has the options, but in Carrara, you can choose to save the IMap and whether or not to reuse it. If you reuse, then it does indeed skip the pre-calculation. Quoting *their* docs:
"*When working on a static scene, you can also save an irradiance map and then reuse the map
over and over to render it from different point of view.
You can also use this feature for some more interesting effects. For instance, you could render
the irradiance map for a scene without texture so that the Global Illumination solution is faster
and less noisy and then use that* irradiance *map to render your scene with the texture applied."
spod ( ) posted Thu, 29 April 2010 at 12:29 PM
So, the files are probably associated with irradiance caching, and they are probably a waste of space.
Does anyone have any idea how they might be used in subsequent renders of the same scene but with characters whose positions and poses have changed, in order to reduce the time used for pre-calculation during rendering?
I should mention that these are big files, at least as big as the scene file itself.
lmckenzie ( ) posted Fri, 30 April 2010 at 4:48 AM
The person to ask would probably be Stewer, so you might try sending him an IM.
