possible, but unnecessary (in the case of Poser). As for Hexagon, I dunno...but they have a forum here.
Usually they're made when you create an .obj file...I think you'd want the .obj file with it, in the case of Hexagon (or it likely wouldn't have a usable reference).
I can import obj files containing a reference to an mtl file, and the textures import correctly. It should work as long as all the references are correct.
Does the obj file contain the mtllib reference?
Is the referenced mtl file in the expected location?
Are the referenced texture maps in the correct location?
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
A sub-folder also works fine for me. The texture map references in the mtl file must of course include the sub-folder name.
what I should be."
Murakami)
Is it posibble to import mtl-files into poser or hexagon ?
