Tue, Jan 28, 4:09 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Subject: MTL-Files
megaionstorm ( ) posted Fri, 30 April 2010 at 11:20 PM · edited Tue, 28 January 2025 at 3:53 PM
Is it posibble to import mtl-files into poser or hexagon ?
pakled ( ) posted Fri, 30 April 2010 at 11:24 PM
possible, but unnecessary (in the case of Poser). As for Hexagon, I dunno...but they have a forum here.
Usually they're made when you create an .obj file...I think you'd want the .obj file with it, in the case of Hexagon (or it likely wouldn't have a usable reference).
megaionstorm ( ) posted Sat, 01 May 2010 at 5:46 AM
I have a object in obj-format. If i import it, it's untextured. This informations are saved in the mtl-file.
IsaoShi ( ) posted Sat, 01 May 2010 at 7:14 AM · edited Sat, 01 May 2010 at 7:15 AM
I can import obj files containing a reference to an mtl file, and the textures import correctly. It should work as long as all the references are correct.
Does the obj file contain the mtllib reference?
Is the referenced mtl file in the expected location?
Are the referenced texture maps in the correct location?
markschum ( ) posted Sat, 01 May 2010 at 10:10 PM
the texture maps need to be in the same folder as the obj and mtl file.
There is a very limited range of parameters that the mtl file will handle.
diffuse, specular, bump, transparency and I think reflection .
IsaoShi ( ) posted Sun, 02 May 2010 at 5:24 AM
> Quote - the texture maps need to be in the same folder as the obj and mtl file.
A sub-folder also works fine for me. The texture map references in the mtl file must of course include the sub-folder name.
