Fri, Dec 20, 1:51 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 19 10:29 pm)
Subject: Prop creation question?
uncle808us ( ) posted Sat, 01 May 2010 at 2:47 PM ยท edited Mon, 18 November 2024 at 7:31 PM
I have a lot of props for an object. I want to be able to have one prop. But with all the separate props contained in the one prop. How do I do this in Poser 7 ? I want to save the one prop to my library as a pp2 and export the object as a wavefront obj file. I hope this is not too unclear to understand what I'm trying to do. Thank you. End result is to be able to Y rotate the steering obj.
MacBook Pro OSX El Capitan Ver 10.11.6
markschum ( ) posted Sat, 01 May 2010 at 3:17 PM
Open the hierarchy editor , and place all the props into the proper hierarchy . Then select the base part of the props and use the create figure button near the bottom to create a figure.
If you do it right you should be able to have the steering operate. You might need to hide a lot of the dials.
Anither way is to parent all the parts and export it as one group. That should combine all the objs into one.
uncle808us ( ) posted Sat, 01 May 2010 at 5:46 PM
Well I tried the first version but got bad results when trying to rotate the body part steering here's what I got.
nruddock ( ) posted Sat, 01 May 2010 at 6:33 PM
You appear to have made a figure rather than a set of parented props.
In this case you'll need to turn off bending for the various elements (that's only applicable to organic rather than mechanical objects) and also the JPs and axis order will need setting properly.
uncle808us ( ) posted Sat, 01 May 2010 at 6:42 PM
What are JP's and axis order is that the joint editor?
nruddock ( ) posted Sat, 01 May 2010 at 7:20 PM
Quote - What are JPs and axis order is that the joint editor?
Yes.
You might want to look over some of Dr. Geep's and PhilC's tutorials dealing with figure creation and adjusting JPs.
uncle808us ( ) posted Sat, 01 May 2010 at 7:23 PM
Right I remember PhilC joint position tut. I will Thanks.
xantor ( ) posted Mon, 03 May 2010 at 2:36 AM
For a figure like this you should switch off bending for all the parts.
uncle808us ( ) posted Mon, 03 May 2010 at 9:03 AM
Thanks guys turning off bending worked.
