Wed, Dec 4, 4:32 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 4:13 pm)
Subject: need help for loading v4 character in poser pro
lancerdoom1 ( ) posted Wed, 05 May 2010 at 5:37 AM · edited Wed, 04 December 2024 at 4:28 PM
hi, i am new to poser please help me
i have DAZ3D product "Anarani" for V4 . and i have installed it completely .
http://www.daz3d.com/i/shop/itemdetails/?item=7759
but how can i load this in my poser 8 pro
i have installed victoria 4.2 and its morphing installer that is
ps_pe069_Victoria4.exe
ps_pe070_V4Morphs.exe
but when i start poser the default man load up. how can i change to my Anarani character.
there is no figure by the name of anarani in figures options.....!
hborre ( ) posted Wed, 05 May 2010 at 6:11 AM
First, you are confusing the issue by posting several Poser versions.  Please use the correct title for the software you have installed.  Is it Poser 8, PoserPro, or PoserPro 2010?
Second, where did install V4 and her morph++ package?  The model does not automatically appear when you start your app.  You would need to delete the Andy character from your scene, then under the Figures category, !Daz People folder, you will find your V4 model to load into the scene.  To inject the morph pack, you need to navigate to the Poses category, and open, IIRC, DAZ Victoria4 folder.  I don't know how the particular Anarani is packaged, but I am going to assume that it is a morph pack, and should also be located in the Poses Category of the library.
lancerdoom1 ( ) posted Wed, 05 May 2010 at 6:17 AM
its the poser pro version
the victoria base 4.2 and morph pack i installed individually.....
the anarani is based on 2 setup file that in installed 1 by one.....
but i cant find any anarani character in figures category.........
how can i load the character ?
nruddock ( ) posted Wed, 05 May 2010 at 6:38 AM · edited Wed, 05 May 2010 at 6:47 AM
Quote - ... but i cant find any anarani character in figures category.
You should find the necessary files under Poses.
All the DAZ items come with a list of what files are included and where they're located after installing, so when you can't find something, all you need to do is open that list either directly from the ReadMe folder or via the link in the ReadMe itself.
hborre ( ) posted Wed, 05 May 2010 at 6:44 AM
Quote -   I don't know how the particular Anarani is packaged, but I am going to assume that it is a morph pack, and should also be located in the Poses Category of the library.
I thought I made that point clear in my post.
TrekkieGrrrl ( ) posted Wed, 05 May 2010 at 7:31 AM
Poser Pro is like 10 years old. I doubt that's the version you have. Since then, there's a Poser 7 Pro and Poser Pro 2010. Please state which one you've got (although I'm asuming it's the 2010 version.. just wanting to be sure)
hborre ( ) posted Wed, 05 May 2010 at 7:34 AM
The original was know as Poser Pro Pak.  Hardly a consideration these days.  And please, there is no such a beast a Poser 7 Pro.  Just PoserPro and PoserPro 2010.
basicwiz ( ) posted Wed, 05 May 2010 at 1:08 PM · edited Wed, 05 May 2010 at 1:11 PM
I am assuming if you just bought the program, you are running Poser Pro 2010. If that is the case, then here is what I believe you are looking for... click by click.
  1. Open Poser
  2. Go to the "Figure" menu (third from the right in the grey bar near the top of the screen) and select "Delete Figure" from the options that will appear. Andy will vanish.
  3. In your Poser Library screen, click on "DAZ People." Under that menu, click on "Victoria 4.2." She will load.
  4. Click on the second round Icon near the top of the Poser Library window (the running man)
  5. Click on the folder "DAZ's Victoria 4" there.
  6. Click on the folder marked "Morph Injections"
  7. Click on the icon that says "INJ Base V4". Let it load.
  8. Click on the Icon that says "INJ Morphs ++ V4." Let it load (may take a few seconds)
At this point you have loaded the base V4 character. My suggestion is to take a little side trip and save her this way so you don't have to do all of this again. To do this:
  1. Click on the first round Icon at the top of the Poser Library.
  2. Click on Victoria in the Pose screen. It doesn't matter what part of her you highlight... just make sure she is selected.
  3. Click the LARGE plus icon at the bottom of the Poser Library Screen. There will be two of them... one inside a folder and one that is just the plus sign. Click the plus sign.
  4. Enter "Victoria 4 + Morphs" Click OK
After a few moments, you'll see a new icon appear in the Library. THIS is the one you load from now on, because it has the morphs saved with it and will not require the earlier process to be repeated again.
To load your character:
  1. Click on the round icon with the running man
  2. There, you will find "Anarani". Open that folder.
  3. Click on the Head and Body INJ files (or the FULL INJ, if there is one)
  4. Find the MAT file in the list. Click on it. The texture will load.
You are ready to pose and render.
If this doesn't work, get back to me. I will be glad to help.
hborre ( ) posted Wed, 05 May 2010 at 2:03 PM
If worst comes to worst, we can illustrate the important points.
basicwiz ( ) posted Wed, 05 May 2010 at 2:06 PM · edited Wed, 05 May 2010 at 2:06 PM
 I started to do that hborre, but I'm in the middle of a job that has to be out the door tomorrow, so my computer is pretty well spoken for. If the OP is still having trouble, I'll try to do some screen caps for him tomorrow.
Great idea! Thanks!
lancerdoom1 ( ) posted Thu, 06 May 2010 at 12:59 AM · edited Thu, 06 May 2010 at 1:13 AM
i have loaded the anarani character but how can i load its clothes and other accessories ?
there are 4 sets included in the pose category that contains 4 different sets of cloths and accessories , but none of them are working or loading when i click them...
basicwiz ( ) posted Thu, 06 May 2010 at 1:42 AM
 See private message
