Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 3:06 am)
First, you are confusing the issue by posting several Poser versions. Please use the correct title for the software you have installed. Is it Poser 8, PoserPro, or PoserPro 2010?
Second, where did install V4 and her morph++ package? The model does not automatically appear when you start your app. You would need to delete the Andy character from your scene, then under the Figures category, !Daz People folder, you will find your V4 model to load into the scene. To inject the morph pack, you need to navigate to the Poses category, and open, IIRC, DAZ Victoria4 folder. I don't know how the particular Anarani is packaged, but I am going to assume that it is a morph pack, and should also be located in the Poses Category of the library.
Quote - ... but i cant find any anarani character in figures category.
how can i load the character ?
You should find the necessary files under Poses.
All the DAZ items come with a list of what files are included and where they're located after installing, so when you can't find something, all you need to do is open that list either directly from the ReadMe folder or via the link in the ReadMe itself.
Poser Pro is like 10 years old. I doubt that's the version you have. Since then, there's a Poser 7 Pro and Poser Pro 2010. Please state which one you've got (although I'm asuming it's the 2010 version.. just wanting to be sure)
I am assuming if you just bought the program, you are running Poser Pro 2010. If that is the case, then here is what I believe you are looking for... click by click.
At this point you have loaded the base V4 character. My suggestion is to take a little side trip and save her this way so you don't have to do all of this again. To do this:
After a few moments, you'll see a new icon appear in the Library. THIS is the one you load from now on, because it has the morphs saved with it and will not require the earlier process to be repeated again.
To load your character:
You are ready to pose and render.
If this doesn't work, get back to me. I will be glad to help.
hi, i am new to poser please help me
i have DAZ3D product "Anarani" for V4 . and i have installed it completely .
http://www.daz3d.com/i/shop/itemdetails/?item=7759
but how can i load this in my poser 8 pro
i have installed victoria 4.2 and its morphing installer that is
ps_pe069_Victoria4.exe
ps_pe070_V4Morphs.exe
but when i start poser the default man load up. how can i change to my Anarani character.
there is no figure by the name of anarani in figures options.....!
