Quote - so you are saying- my poserpro is a higher version? i am not familar with lwo or importing there in- just needed a police car and there were what i found. i tried exporting as a obj and then appling the tex then but same result
So my language not so good sometime, I try again;
Poser only can import Lightwave Objects up to Lightwave version 5.6, those versions do not have UV mapping only object space mapping. You have to convert the LWO file to some other format and UV map it. Straight forward way is convert to OBJ and use some UV mapping application, there are many and most modeling programs contain one also
(thank you for explaining it again- btw ya english is fine chances are it is me) yeah i am noticing that-plus i have located poserRay but seems it has not been tested in winos it is worth a try about to look into some uvmapping proggies- and if it ends up being to much effort for this, which ironically is to sever a bg filler then i will take the texture loss- not a big deal.
i have no trouble importing now working in the mat room and nodes and such- but the textures dont seem to show- any suggestions?
thanx in advance
