I'm using poser 7 and I'm not sure how to properly add GC to a shader. Do I just plug them into the alt diffuse node?
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
Sometime ago, Bantha put together a gamma correction python script which installs the necessary shader nodes. They do plug into the alt_diffuse of the root node. Very convenient and handy. Used it several times in P8 before PP 2010. I thought it was posted in the free section, but haven't found it. I do know it was posted here in the forum last year. Perhaps, if you get in touch with him, he would be more then happy to release it again.
And BTW, if you do begin to use it on a regular basis for everything, you will need to drop your light intensities.
I'll look up that bantha script. Also, what are good light levels?
WARK!
Is there something important I'm missing here?
WARK!
Quote - you're double correcting and not linearizing, i think. the first power function should be to 2.2, not 1/2.2.
Precisely so. Plug the output of Math_Functions_3 directly into Value 2 of Color_Math_4. Change nothing else until you've rendered that!
Edit: well, you could put the Diffuse_Value back to what it was originally...
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
Please, don't kill me...
"Oh - the manual says that? I have never read the manual - this must be why."Thanks kobalt and Isao... that's what I get for trying to build nodes so late at night.
WARK!
WARK!
Looks like I'm back to square 1. ;)
WARK!
