Sat, Jan 11, 8:49 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 11 12:30 am)
Subject: Best render setting?
Mariny ( ) posted Sun, 16 May 2010 at 12:36 PM · edited Sat, 11 January 2025 at 6:20 AM
 Hi.. I haven't render many renders in D|S and wonder what render settings get the sharpest,most realistic render??
Mariny
animajikgraphics ( ) posted Sun, 16 May 2010 at 1:51 PM
Depends on what you're rendering, your shaders and your lighting used. Also, you're goning to get better quality (and speed) from DS3, than using DS2)
Too many factors to give a one-size-fits-all answer.
FatCatAlley.net | Now Playing "SpaceCat 5" Parts 1 and 2
AnnieD ( ) posted Sun, 16 May 2010 at 2:32 PM
You could look at the tutorials here...I seem to remember a couple that deal with that subject.  Or look at the Daz tutorial site..at least it would give you a starting place.
“For those who believe, no proof is necessary. For those who don't believe, no proof is possible.”
[Stuart Chase]
mishamcm ( ) posted Sun, 16 May 2010 at 5:32 PM
The first thing to do is lower the shading rate -- the default value of 1 is fine for draft renders, but for a sharp image you'll want to lower it to .5 or .2 -- but it will take longer to render.
LBAMagic ( ) posted Thu, 20 May 2010 at 10:30 PM
As AnnieD said "You could look at the tutorials here....". Under Renderosity tutorial section for Daz Studio there is a good a tutorial called Optimising render settings in DAZ|Studio.
Note, if you do decrease your shading rate as mishamcm said then render time would be longer but the image would be sharper.
As AniMajikgraphics "Too many factors to give a one-size-fits-all answer". After two years I'm still experimenting.
