Fri, Jan 3, 5:59 PM CST
Subject: Why does this happen?
Prometheus273 ( ) posted Mon, 24 May 2010 at 5:46 PM · edited Fri, 03 January 2025 at 5:49 PM
This is the Michael 2 suit.  In Preview mode it looks fine.  But when I render it in firefly it looks semitransparent.  Not sure it shows well in the attached pic but even the sleeves are semitransparent.   I checked the materials and there is no transparency map loaded.  All materials are set to 0% transparency.  This is Poser 7 with all updates, by the way.
RobynsVeil ( ) posted Mon, 24 May 2010 at 5:56 PM
Would you be able to show us a screen-capture of the material room (advanced) please?
Also, are normals set to forward?
Metaphor of Chooks
Prometheus273 ( ) posted Mon, 24 May 2010 at 6:20 PM
I set normals to forward as you suggested and then rendered again.  Even the pants are semitransparent
seachnasaigh ( ) posted Mon, 24 May 2010 at 6:41 PM · edited Mon, 24 May 2010 at 6:42 PM
The transparency edge value is set at 1;  this will cause transparency in obliquely-viewed areas.  Set it to 0.
RobynsVeil ( ) posted Mon, 24 May 2010 at 6:46 PM · edited Mon, 24 May 2010 at 6:47 PM
What seachnasaigh said...
...this is why I like to see the shader itself.
Metaphor of Chooks
markschum ( ) posted Mon, 24 May 2010 at 7:09 PM
gee if you can read that pic I need better glasses :)
RobynsVeil ( ) posted Mon, 24 May 2010 at 7:12 PM
Um, I could barely make out that 1under transparency_edge... you do have a point, Mark.
Metaphor of Chooks
Prometheus273 ( ) posted Mon, 24 May 2010 at 7:15 PM
That was it.  Thank you very much everyone.  Only some of the bodyparts were set like that.  Don't know how they got changed.  Thanks again.
