Sat, Nov 16, 8:24 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 9:11 am)
Subject: So far no go installing V4 into Windows 7
Darboshanski ( ) posted Sun, 16 May 2010 at 5:38 PM · edited Mon, 04 November 2024 at 6:23 PM
I can't seem to get past this point without this error popping up so I can't even point the installer to any directory. I am using Windows 7 64-bit Poser and all installed great I can't get Daz people to install.
My Facebook Page
Victoria_Lee ( ) posted Sun, 16 May 2010 at 5:51 PM
You might have to do it via the dummy poser.exe file.  I didn't have that problem so I don't know what to tell you.
Hugz from Phoenix, USA
Victoria
Darboshanski ( ) posted Sun, 16 May 2010 at 5:54 PM · edited Sun, 16 May 2010 at 5:55 PM
The problem is I can't get that far to even point the installer to any file dummy or not. The error occurs before I can select a poser file to install to.
My Facebook Page
hborre ( ) posted Sun, 16 May 2010 at 6:24 PM
First, which Poser version are you using?
Second, Are you sure you are using the Poser installer and not the Daz studio?
Victoria_Lee ( ) posted Sun, 16 May 2010 at 6:26 PM
Question:  what is the file you're trying to install?  Is it one that has _DS in the name?  If so, that's a studio specific file and you can't install them without Studio.
I don't even download them because I don't have DS any longer.  You need to make sure the file is a ps-whatever for Poser.
Victoria
Khai-J-Bach ( ) posted Sun, 16 May 2010 at 6:30 PM
Windows 7?
you installed into Program Files did'nt you?
Darboshanski ( ) posted Sun, 16 May 2010 at 6:49 PM
Nothing you folks pointed out apply sorry lol.  If you look at the error message " error reading INI file C: Program Files (86x)Common FilesDAZdazInstall.ini" the file never installed to anywhere because it couldn't. You see the dazInstall.ini file was missing. It  kinda gave me a clue after I sat here and read it long enough and finally the light went on.
I went to the C: Program Files(86x)Common Files in Windows 7 only to find there was no DAZ folder there with the dazInstall.ini file in it. So the installer is looking for the Daz folder that isn't even there. It was no wonder I got the error.
 So I created a DAZ folder in the Windows 7 program files(86x>commons files yada, yada then went into the Windows.old folder and copied the dazIntsall.ini and pasted into the new Daz folder in Windows 7. Now she installs no problem. Without the ini file you never got past the error message to point the installer to ANY directory whether it be in the Program files or on the moon. ; )
My Facebook Page
hborre ( ) posted Sun, 16 May 2010 at 6:50 PM
In another post, Kaibach, PaganArtist upgraded from Vista to W7.  If Poser worked correctly in Vista, I would assume that it is working well in W7.  But, yeah, the Program Files issue can prresent a problem/
Khai-J-Bach ( ) posted Sun, 16 May 2010 at 6:55 PM · edited Sun, 16 May 2010 at 6:57 PM
I was thinking it was UAC again.
"I went to the C: Program Files(86x)Common Files in Windows 7 only to find there was no DAZ folder there with the dazInstall.ini file in it. So the installer is looking for the Daz folder that isn't even there. It was no wonder I got the error."
is exactly the behavior I'd expect to see with UAC blocking it..... I get it all the time with certain installers.. it's why I stopped using program files if I can avoid it.
Darboshanski ( ) posted Sun, 16 May 2010 at 6:57 PM
Poser is working better in Windows 7 then it did in Vista. I had a few issues with Poser 8 and Poser Pro 2010 that don't seem to be there now.
My Facebook Page
Anniebel ( ) posted Sun, 16 May 2010 at 11:05 PM
Actually it isn't a Windows problem it is a bug in the DAZ installers. There is a thread in the Nuts & Bolts forum about all the problems with the installers HERE, see specifically the post by Tjeerd Doosje, he/she posted a fix, which you more or less did yourself anyway.
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
Marque ( ) posted Mon, 17 May 2010 at 10:07 AM
It says daz install, so wondering if as stated above if it is a ds file, should be installing to the poser subdirectory. Also if you are trying to install and your poser dir is in the 64bit that could be the problem as I notice it's trying to install into the x86. At any rate check again to make sure it isn't a ds unless you are specifically putting it there in the daz directory. I created a small txt file and stuck it in the directory and renamed it poser.exe, that solved my V4 install problem.
Anniebel ( ) posted Tue, 18 May 2010 at 12:12 AM
No it says it is dzinstall because it is to do with the DAZ installers, I think it is actually to do with how the installers (at least the newer ones) remember the last directory you installed to, that is the info stored in the ini file.
Helen Keller
Dynamo ( ) posted Tue, 18 May 2010 at 6:46 AM
I simply targeted the installers to "Daz Studio" ad everything went like a charm for V4,M4,SF4 and F4.
HollywoodBest ( ) posted Wed, 26 May 2010 at 10:08 AM
Yes that was annoying issue I was told to use one of the old installers like the V4 Developers Kit uses the old installer to have that create the necessary file and then you can use the new installers like a charm. But you found your solution now I am searching the forums for Poser 8 continuous crashes that is driving me crazy.
