Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:03 am)
Probably the simplest way is to go to the Material Room and make it transparent. Set Diffuse, Specular and Ambient to zero, set Transparency Value to 1, Transparency Edge to 1 and everything else after that to zero.
Uncheck Reflect Lite Mult and anything else that's checked, also.
That should do it.
Is the buckle a seperate material group ? if it is then set diffuse and specular color to black and transparency to 1 .
If its not then you can try the grouping tool , select the entire hat, deselect the buckle, and use the spawn prop option to make a new version of the hat.
Or you could select the buckle and make it a new material group, then set it to transparent.
Next method is a transparency map , or load it into a modelling program o edit it.
A lot will depend on if the hat is complete behind the buckle.
I have a hat that has a buckle on a strap that goes around the hat (it's a leprechaun hat) and I want to remove the buckle.
How do I do that?
