Thu, Feb 13, 9:03 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:03 am)
Subject: How do I take a buckle off a hat?
Michaelab ( ) posted Mon, 31 May 2010 at 10:25 PM · edited Thu, 13 February 2025 at 8:59 AM
I have a hat that has a buckle on a strap that goes around the hat (it's a leprechaun hat) and I want to remove the buckle.
How do I do that?
SamTherapy ( ) posted Mon, 31 May 2010 at 10:34 PM
Probably the simplest way is to go to the Material Room and make it transparent.  Set Diffuse, Specular and Ambient to zero, set Transparency Value to 1, Transparency Edge to 1 and everything else after that to zero.
Uncheck Reflect Lite Mult and anything else that's checked, also.
That should do it.
markschum ( ) posted Mon, 31 May 2010 at 10:38 PM
Is the buckle a seperate material group ? if it is then set diffuse and specular color to black and transparency to 1 .
If its not then you can try the grouping tool , select the entire hat, deselect the buckle, and use the spawn prop option to make a new version of the hat.
Or you could select the buckle and make it a new material group, then set it to transparent.
Next method is a transparency map , or load it into a modelling program o edit it.
A lot will depend on if the hat is complete behind the buckle.
Michaelab ( ) posted Mon, 31 May 2010 at 11:29 PM
Thanks SamTherapy and markshum,
I used the grouping tool option and deselecting the buckle. Didn't know about that so it was something knew I learned. Thanks. The making it transparent worked as well, thank you.
I appreciate your help.
Michael
