Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Can you post a image from the alph transparency image? Maybe need to invert the map...
Follow me at euQfiz Digital
I would rather
be Politically Incorrect,
Then have Politically
Correct-Incorrectness!!!
Can you send this plant to me to my e-mail so I can see more close what is happen? euqfiz@euqfiz.com.br
You are using a whole tree as a billboard. I am having trouble with Leaves on an Imported X Frog Tree Object. I can't figure out why I can import into Vue, Bryce and Terragen 2 and it is OK, but when I import into Carrara, any version from 5 up, the leaves don't want to work!!!
I would rather
You're not using reference shaders somewhere in the list are you? I've found on occasion some peculiarities with how alpha or transparancy handles things in those instances. (Seems to be a bug in versions 5 & 6.) Instead of using the references, you actually have to copy and paste settings over from the other shader. In my case I discovered it since it was a pain in the butt trying to figure out why a shader based decal wouldn't apply properly.
It could also be one of the texture map settings, I'd play with the premultiplied or color/alpha toggles. Sometimes alpha or transparency seems to work better with .tga or .png images that have actual alpha to it.
Originally the texture files were TIFFs. TIFFs, as you know, can carry their own Alpha and Color Channel. Some of them I have are like that and others have a seperate Alpha and Color. After failed attemps I converted the Textures to Bitmaps and JPGs and created my own Alphas on those that did not have one. The odd thing to me is that the objects and textures work perfect in Bryce, Vue and Terragen 2. Although they have to be manually loaded in Terragen 2, but after that they look great.
All I have done is to add the Color Texture in the Color slot and the Alpha Transparency in the Alpha slot. If there is another way to go about doing this, please tell me and maybe showing me your shader tree might work along with a brief explanation.
Thanks.......
I would rather
I have been going through All my X Frogs and odd thing is the Palm type tree seems to be OK, but it is the Broadleaf and Pinus variety that do not work.
I concur with you about your source, those trees seems to work well and I have used some of the Broadleaf TIFF files on them and theye work just fine. Understand this. The Froggers I have were Free in dot MAX format. So I downloaded the 30 day free trial of 3DMax2009 and converted them to Wavefront Object. This worked very well in all my other landscape apps ie Vue and Terragen 2 and a friend tried them for me in Bryce and said they are great, but not so in Carrara and as I said above I am finding it is the Broadleaf and the Pinus, (Pines, Furs, Cypress etc.), that are giving me the problems. I will do a render in T2, Vue and Carrara of the White Fur and be back soon for a posting of the results.
I would rather
I would rather
It's the same in Carrara 7, 6, and 5. I use the textures I have from any of the X Frogs and they work in AL09 and AL18 with no problems. Here's what happened: I downloaded 58 3DMAX // X Frog files. Someone had converted them from X Frog to dot MAX format. I in turn Downloaded the free 2009 version of 3DMAX and converted the files to Wavefront Object and they work just fine in everything except Carrara, but the kicker is that some of the file do work in Carrara, only the flowery and tropical trees and plants. As stated above the Broadleaf and Pinus varieties do not work in Carrara, any version of Carrara that I have.
I would rather
I'd take a stab at one of those. If I can manage to fix it, I'll send it back as a C6 .car file.
The more people on it, the better. Right?
I am actually caught up between wanting to purchase XFrog or Onyx Tree Suite. Both offer an exceptionally realistic and powerful plant modeler. There is just so much free XFrog floating around I haven't made up my mind!!!
I would rather
Quote - Do you really need it?
With all the freebees and what you can actually make in Carrara-=-what actual real USE would you get from more apps?Buy when you have a need not a percieved need!
Brian
How True, How True and _ _ _ !!!
I would rather
![file_454419.jpg](https://live.cdn.renderosity.com/forum/threads/2804096/file_454419.jpg)
I thought I would see if you guys and gals can help me with a little problem I am having with the importing of X Frog Plants from Object format. The problem is that the leaves do not import with transparencies. Seems no problem to fix right? So I try to manually add the texture maps in the shader tree in the correct positions and I do get transparency alright, Total Transparency. In this first image you see my Assembly Room and that the tree although it has color does not have transparency to shape the leaves.I would rather be Politically Incorrect,
Then have Politically Correct-Incorrectness!!!
