Sun, Jan 26, 4:47 PM CST
Subject: desert soldier m16 assault rifle
salmonfisher ( ) posted Fri, 07 May 2010 at 12:43 PM · edited Fri, 19 July 2024 at 8:52 AM
hi im using the model michael 3 sr1 how do i parent this m16 to his hand.
i am new to poser and i cant figure how??
BAR-CODE ( ) posted Fri, 07 May 2010 at 12:50 PM
you put it in the right place by HAND ..and THEN you select Parent to Left or Right Hand ..
Then you Resave it ..as "m16 Lefthand" next time you use it it wil be in his hand were you put it ..
If its not parented in the first place you have to do it yourself..
You can parent and not save it ..but then you need to replace it every time again..
Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A  PM to 26FAHRENHEIT  "same person"
Chris
My Free Stuff
hborre ( ) posted Fri, 07 May 2010 at 1:23 PM
Online Now!
Of course, this means that you will need to pose the hand and fingers to actually hold the weapon which can be tedious for users.  If you manage to get that far, I strongly recommend you save the hand pose into your library under the Hands Category.
salmonfisher ( ) posted Fri, 07 May 2010 at 3:45 PM
yea i know:
what im trying to achieve is a soldier holding a gun with both hands and walking .
but when i use symmentry sorry for the spelling but you know what i mean the legs are ok but the arms are all wrong.
i have the pose correct i.e holding the gun and walk position how do i mirror the pose ??
pakled ( ) posted Sun, 09 May 2010 at 9:25 PM
I think they're using M4's for the most part now (but I digress...;)
estherau ( ) posted Sun, 09 May 2010 at 9:40 PM
Attached Link: panko's weopons
 these guns are my weapons of choice.  There are guns and poses to put the guns in his hands, eg walking with the gun or firing it, and some for M3, M4, V3 and V4 depending which set you buy. The readme with these products clearly tells you how to do it. Have fun. Don't shoot yoruself in the foot or blow up your runtime. Love esther
MY ONLINE COMIC IS NOW LIVE
Xavier_Leggett ( ) posted Thu, 17 June 2010 at 3:18 PM
I jumped onto this thread after doing a search because I'm having similar weapon posing problems.
I have V4 posed in a firing stance with the WP-38.  Okay, after I position the weapon in place, get her to actually hold the weapon and all looks fine. . . until I change poses, the weapon 'slips' from her grip.  Even if I just pose her legs and not touch her upper body, the weapon still 'slips' or moves from her grip.  I've tried the parenting feature in Poser 8 and when I select 'OKAY' for her right hand--the hand that has the weapon--the WP-38 slips from her grip again.
Even when I have V4 in a zero pose load the WP-38 and select the parent feature, the weapon just floats in space.  Is it this particular weapon, or am I doing something wrong.
My bet is, that it's me whose doing something wrong or missing a step.
Any help is much appreciated.
hborre ( ) posted Thu, 17 June 2010 at 3:37 PM
Online Now!
Is the weapon an actual prop or is it smartpropped to a particular model (i.e., M4, etc).  If it is smartpropped, import the weapon as an OBJ, position into V4's hand and resave it into the library as a V4 smartprop.
Another method of parenting props, open the hierarchy palette, locate the prop and manually move it to just under the hand body part.
Xavier_Leggett ( ) posted Thu, 17 June 2010 at 3:56 PM
Hey, thanks for responding.
Actually, the WP-38 not a 'prop' it's actually a CR.2 file.  So maybe that's the reason why nothing's working as it should.
salmonfisher ( ) posted Thu, 17 June 2010 at 4:06 PM
hi all i did was to parent the wepon to the models hand and choose the pose needed i have the army pose set "ice pack" it is great for these type of poses im not sure about v4 but im sure you could purchase some for her.
another great resource is posmocap not plugging it i just realy like it. example if you isolate the walk forward and shot to just were he draws the gun you have a nice anim sequence all done for you.
hope this helps
Xavier_Leggett ( ) posted Thu, 17 June 2010 at 6:29 PM
Hey, thanks for all of your advice guys--but I still can't seem to wrap my head around getting this particular weapon to work in Poser 8.
The darn thing works fine in DAZ3D; pose after pose, V4 or M4--it doesn't matter.  I can parent the WP-38, the whole nine years.  But in Poser, it just 'floats' around my model.
I know . . . I know . . . the solution to my problem may be to choose a different weapon . . . or to just use DAZ3D when I want my characters to bust a cap with that WP-38.
hborre ( ) posted Thu, 17 June 2010 at 8:10 PM
Online Now!
I am assuming this is the product you are using:
[http://www.renderosity.com/mod/bcs/index.php?ViewProduct=77092
](http://www.renderosity.com/mod/bcs/index.php?ViewProduct=77092I)If it is, the readme file contains additional information concerning the behavior of the gun.  Under LibrarieshandWalther_P38 there are poses for left/right hand and underneath shoulder for both M4 and V4.  Have you tried these yet?
Xavier_Leggett ( ) posted Thu, 17 June 2010 at 10:41 PM
Yeah, that's the product all right!
When I read your above post i felt kinda stupid.
Then I read the WP-38 readme, and i felt even dumber--if that's possible.
So I dug into my runtime and damned if I couldn't find the hand poses for the WP-38.
So then I checked my download and it didn't contain any hand poses for that weapon, either.
Reckon I'll just have to PM Madd Matt and let him know that I'm missing a couple of files, darn it.
hborre ( ) posted Fri, 18 June 2010 at 10:19 AM
Online Now!
Don't feel bad.  Whenever I encounter a problem, I check the readme for more information.  Some things seem obvious and intuitive,  others need special treatment.  Definitely contact the vendor.  Rendo's QC failed to pick up the packaging problem.
