DAZ|Studio F.A.Q (Last Updated: 2024 Dec 31 6:58 pm)
you always need the ++ morphs..
<a
href="http://www.renderosity.com/index.php?AID=968"><img
src="http://www.renderosity.com/photos/File1557.gif"></a>
Tanya also has a set of INJ/REM that will pre inject the required ++ morphs into V4.2.
One thing is to make sure you are actually using V4.2 and not the QS version that comes with DS, as the Quick Start version is a cutdown version and doesn't have anywhere to inject the morphs into.
[RANT] With such a crappy edit post time it's no wonder this site has so many double & triple posts [/RANT]
I hope you get it to work properly as this is a fantastic model, skin, eyes, etc. One of my favorites.
Images that run around in
my head eventually end up in my
gallery.
Dragons like to have fun too! Dragon Mischief Art
Make sure you have the legacy morph channels enabled in PowerLoader, if you use it. If you don't use PowerLoader, select V4 and go to the Parameter palette; click the triangle button at top-right to get the option menu and if Show Hidden Properties isn't ticked click it; make sure that with the root selected (double-click on the figure) you can see a Morphs++ group under Morphs:Shapes, and with the ehad selected you have both Morphs++ under Morphs|Shapes and INJection Channels groups.
Loaded Tanya model into Daz. Icons are visible and appear to load, but V4 remains unaltered. Does anyone have suggestions? Thanx.
